Proportioning valve question
Im about to upgrade to 11" itr set up and ep3 on the rear , all of this will go into a civic ex 99-00. Now im running a tucked brake line set up that i made.
Is there any difference between the integra and civic si 99-00 40/40 prop valve , beside its shape? can i use the integra one and make some lines for it?
Seagull Management
Re: Proportioning valve question
Yes, the integra valve is setup for larger front brakes, btw '98 - '01 non ABS integras use the same physical style valve as the '96 - '00 Civics.
SportEL
06-21-2010 08:31 PM
