Suspension & Brakes Theory, alignment, spring rates....
correct conversion fitting for 1" MC swap
Old Aug 1, 2011 | 06:18 AM
SQ is the SQUAD's Avatar
Default correct conversion fitting for 1" MC swap
swaping accord ex 1" master cylender into my 95 accord lx. my accord has the two 10x1.0 fitting where the master hat inputs for one ten and one twelve.
so basically i need a adapter fitting that has a 12 male and a 10 female. i went to pepboys but all the conversion fittings where in standard size. there was no conversion charts.
i skimmed through a bunch of the tuck threads, alot of people seem to be using the banjo fittings. what is the correct fitting for just a standard conversion?
Old Aug 5, 2011 | 04:56 AM
K2e2vin's Avatar
Default Re: correct conversion fitting for 1" MC swap
I believe there's really no conversion as the threads are different(I think it was 3/8 that was close, but wouldn't screw-on due to the thread pitch); but found the correct fitting at Advance Auto and it was just labeled "12mm Adapter". It's a M10 to M12 Inverted flare fitting adapter
Old Aug 5, 2011 | 05:23 AM
ok, ill got check there. pepboys had a bunch but they where all standard sizes
riceburnr18
Nov 25, 2007 01:46 PM
khmerxnuttyxb
Jan 21, 2007 03:05 PM
Bendy817
Oct 19, 2005 07:39 PM
