Suspension & Brakes Theory, alignment, spring rates....
suspension problem
Old Dec 16, 2012 | 05:24 PM
specbb6's Avatar
Default suspension problem
Hi everyone, so a couple days ago my front left suspension started making this clicking noise that got louder each time. yesterday I popped the hood to inspect it and noticed that the inner part of the shock (tein ss) was sticking out a lot to the point the it made a dent on the hood!
today, I replaced the coilover with my old oem shock/spring so i can figure out where to fix my tein coilover.
the problem now i that it still makes a lot of noise when i go over small bumps or cracks on the road. I made sure every bolt/nut was in place before taking the road test, so i dont know whats making my suspension sound like theres something loose. I did notice that the axles boot is cracked pretty bad but i dont know if that could be the problem?
do you guys have any idea what to check next?
thanks in advance
Old Dec 17, 2012 | 03:11 AM
grumblemarc's Avatar
The Grumpiest
Default Re: suspension problem
You left a piece out.
Old Dec 17, 2012 | 07:19 AM
specbb6's Avatar
the coilover has been in the car for about 4 years and didnt have a problem until now. I havent worked on the suspension ever since.
do you care to explain "left a piece out"?
Old Dec 17, 2012 | 09:44 AM
tron_'s Avatar
10 Year Member
I think he means you left one of the retaining washers out of the assembly.
Old Dec 17, 2012 | 10:19 AM
specbb6's Avatar
do you mind pointing at which retaining washer?
thanks
Old Dec 17, 2012 | 02:15 PM
The Grumpiest
12
Old Dec 17, 2012 | 02:18 PM
phunhaus's Avatar
Looks to be installed improperly. From what I can tell #12 IS installed but it was either installed over #8 or has pushed through #8 which is damn near impossible.
Old Dec 17, 2012 | 02:24 PM
The Grumpiest
I don't think you should be able to see the #12 part if it was installed properly.
Old Dec 18, 2012 | 11:33 AM
Az-Dc2's Avatar
So these are Tein SS full coilovers? If you just took them out of the box and put them on and they lasted for 4 years you may be SOL because they are outside of the warranty period. Could have been a manufacturing error
Old Dec 18, 2012 | 06:44 PM
danny_ca5's Avatar
I would have to agree with grumblemarc it appears number 12 was not necessarily "left out" but it could be that after 4 years it was able to wear out enough that it can now slide over the strut rod no longer preventing it from traveling completely through the top hat. My Tein Basics came with the retaining washer "welded" or mounted as one piece with the strut rod
Old Dec 18, 2012 | 06:46 PM
danny_ca5's Avatar
did your tein susp come with hardware or did you use OEM hardware?
Old Dec 18, 2012 | 07:18 PM
98civdx's Avatar
Master Detailer
I agree. If #12 was able to push #8 you'd have a big hole in #8.
Every time I have seen this before it was due to improper installtion.
Old Dec 18, 2012 | 10:48 PM
specbb6's Avatar
I used the existing OEM hardware
Old Dec 18, 2012 | 10:50 PM
specbb6's Avatar
do you guys know if the shock can be fixed?
Old Dec 19, 2012 | 04:33 AM
danny_ca5's Avatar
get a close up picture of the shock now that it is removed. I would like to see what the existing white line is around the strut rud up near the bushing. if you can get a close up of that..
Old Dec 19, 2012 | 11:24 AM
specbb6's Avatar
this is how the shock was installed except for #16, 6, 7, 14
Old Dec 19, 2012 | 07:50 PM
98civdx's Avatar
Master Detailer
It's just extended, I would shocked if there was anything wrong with the shock.
Old Dec 19, 2012 | 08:40 PM
specbb6's Avatar
would i have to send it to Tein to have it fixed or do you think they could fix it at shop?
Old Dec 19, 2012 | 08:45 PM
98civdx's Avatar
Master Detailer
Do you have the plate that is above the bump stop?
Old Dec 19, 2012 | 08:53 PM
specbb6's Avatar
the retaining washer, #12?
specbb6
Dec 19, 2012 01:01 PM
ctscloud
12
Dec 24, 2010 12:33 AM
ek9_style
Suspension & Brakes
Apr 28, 2009 02:27 PM
jianshu
Honda Civic (2006 - 2015)
Jan 30, 2008 06:33 PM
crs
23
Jan 18, 2003 07:53 PM
