Suspension & Brakes Theory, alignment, spring rates....
Do I need a spring compressor?
Old Jun 18, 2005 | 07:48 PM
Blazin Civic's Avatar
Default Do I need a spring compressor?
I am taking off my stock suspension and adding some koni yellows and H&R sport springs. Since I don't need to remove the old springs do I still need a compressor? Also it says in my H&R instructions that the springs are designed to be completely compressed when loaded. Can anyone explain that?
Old Jun 18, 2005 | 08:30 PM
EK k kay's Avatar
Default Re: Do I need a spring compressor? (Blazin Civic)
I'd rent one from autozone just in case. They make you place a deposit and when you return it they refund all of it back. You can rent it forever if you want then return it like 50 years later. With my Tein S-Tech springs I didn't need it. I just put the top hat over the spring over the shock and had someone give it a little weight to compress the spring enough for me to be able to screw the top nut on.
Old Jun 18, 2005 | 10:27 PM
solareclipseauto's Avatar
Default Re: Do I need a spring compressor? (chowmien)
you need the top hats of the stock shocks so you need to take it apart. if you dont know what you are doing go get a spring compressor to take it apart.
Old Jun 19, 2005 | 09:00 AM
daddyshatch's Avatar
Default Re: Do I need a spring compressor? (solareclipseauto)
Yes, you can rent one at Autozone.
Old Jun 19, 2005 | 09:16 AM
So there is no way of doing this without the compressor?
Old Jun 19, 2005 | 09:23 AM
97tegGS's Avatar
you won't need the compressor unless your removing the stock springs. Just get a buddy and when you go to install the top nut just push down (it won't take much but hard to do by yourself)
Old Jun 19, 2005 | 09:33 AM
Default Re: (97tegGS)
Ok so the spring wont go flying when I take the top hat off?
Old Jun 19, 2005 | 09:49 AM
97tegGS's Avatar
The stock one yes, aftermarket no
Old Jun 19, 2005 | 10:04 AM
if your going to do it without a spring compressor put a tire flat on the ground at put the bottom of the shock up against the tire so when you pop it the tire absorbs some of the pressure, be carefull though
Old Jun 19, 2005 | 01:45 PM
Default Re: (solareclipseauto)
Ok well I got the spring compressor and I got the front shock off and i have a problem here. the compressor I got doesn't fit inbetween the coils. Can i loosen the nut a bit on the top hat to loosen the coils a bit to fit the compressor or no?
Old Jun 19, 2005 | 02:10 PM
Default Re: (Blazin Civic)
Haha ok I got that in and now the ******* 15 mil on the top hat gets tp the top and just spins and wont come out
Old Jun 19, 2005 | 08:31 PM
bluedxhatch's Avatar
lube it up; you might need an impact
Old Jun 19, 2005 | 10:13 PM
Default Re: (bluedxhatch)
you can stik an allen wrench in the top and loosen the bolt with a open wrench
Old Jun 19, 2005 | 10:55 PM
Haha yeah I figured that one out eventually. Front is done and will do the back tommorow. This is my first mechanical DIY job really. I install ICE for a living so I do have some backround and I read about hondas all the time.
Old Jun 20, 2005 | 01:23 AM
chusoblu's Avatar
Always fun to DIY, albeit it may take a good chunk of time.
Old Jun 20, 2005 | 05:53 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote">Haha ok I got that in and now the ******* 15 mil on the top hat gets tp the top and just spins and wont come out</TD></TR></TABLE>
impact will do the trick.
suspension is a bitch without air tools..
Dee A Nine
Suspension & Brakes
Aug 29, 2006 05:52 PM
Dee A Nine
Aug 29, 2006 04:27 PM
mike9571
Nov 28, 2005 01:12 PM
dungsta
Suspension & Brakes
May 2, 2005 10:34 AM
CRX-RX
Jan 23, 2002 10:49 AM
