Suspension & Brakes Theory, alignment, spring rates....
On Going Wobble
Old Jun 13, 2005 | 12:12 AM
garylythgoe's Avatar
Default On Going Wobble
I've had a wobble for a while now.. About 6-7months.. And i just cant seem to cure it, so i've come to you guys for some help/advice.
Im running a JDM EF8 CRX, with Tein Coilovers, Cusco upper and lower bars etc.
Ive had a problem where my steering shimmy's/vibrates most noticeably from 50-80mph.. When given load (i.e throttle) it tends to do it ever so slightly worse.. Not enough to make me think its the Inner CV..
18months/2 years ago i had the Track/Tie Rod Ends done (Could they be shot in this amount of time?)
New wheels and tyres have gone on.
New brake discs and pads.
I just brought 2 v.good driveshafts and greased them up properly and put them on.
New intermediate shaft went on.
Proper 4 wheel allignment was done a few times.
Im running out of things to change, and i need some advice.
I noticed one of the ARB bushes was completely gone, this shouldnt really cause a shimmy should it? Im going to change it anyway.
Im going to change lower ball joints also, and theres no play in the wheel bearings, but should i change them anyway?
What else is there that could be an issue? Im losing the will to live with this car
Modified by garylythgoe at 11:47 AM 6/13/2005
Old Jun 13, 2005 | 11:28 AM
shortyz's Avatar
Default Re: On Going Wobble (garylythgoe)
the EF shake, i would also like to know since i have it. i just live with it.
Old Jun 13, 2005 | 12:15 PM
solareclipseauto's Avatar
Default Re: On Going Wobble (shortyz)
were the wheels balance correctly
Old Jun 14, 2005 | 01:47 PM
Default Re: On Going Wobble (solareclipseauto)
Yes lots of times, brought new wheels and tyres aswell
Old Jun 14, 2005 | 02:36 PM
crxtreme89h's Avatar
I have the same problem. I will be swapping my outter tie rods and lower ball joints here pretty soon. I will post up if it has solved the problem.
Old Jun 14, 2005 | 11:18 PM
Default Re: On Going Wobble (crxtreme89h)
How soon man?
Also, anyone got any advice?
Old Jun 20, 2005 | 12:37 AM
bump for some advice from anyone!
Old Jun 20, 2005 | 05:54 AM
be.twenty's Avatar
any grinding sounds? ....if so, that could point towards wheel bearings.
Old Jun 20, 2005 | 12:52 PM
Default Re: (99_dc)
No dodgy noises..
Front end just feels kinda loose over bumps
Old Jun 20, 2005 | 12:58 PM
radzer0's Avatar
Default Re: (garylythgoe)
had the same thing here in my DA.. inner cv joint :\
Old Jun 20, 2005 | 01:10 PM
Default Re: (radzer0)
how bad was the wobble?
Old Jun 21, 2005 | 02:29 AM
Contender25
Guest
Posts: n/a
Yeah it's a wierd prob, my last 2 hatchback's din't have this prob, one of them was 89 si 5 spd, perfect chassis, the other 90 std....piece of crap chassis, and well niether had that prob. But anyways i noticed what u were sayin cause it's a strange prob with certain ones or models i think cause my moms dx 5 spd 89 hatch has this prob, but then again shes one of them peeps that doesn't downshift to slow down to preserve brake life like me, she just does fast constant stops from 50 or so, but not too fast...unless she has too. I tell her to take it easy sometimes, but she doesn't care.
E-AT_me
16
May 25, 2010 02:30 PM
VTEC-LUDE
Jan 6, 2007 08:52 AM
K-Spec
Oct 22, 2006 08:19 PM
JDM_SOHC
Oct 16, 2005 07:45 AM
iNetForce
Jul 19, 2004 01:31 PM
