Suspension & Brakes Theory, alignment, spring rates....
Squeaky steering....
Old Nov 9, 2006 | 03:08 PM
jostins_gsr's Avatar
Default Squeaky steering....
I was driving one day and I started to turn and it made a really high pitch squeaking noise from the front....while at a stop I turn the wheel side to side, the squeak is there...when I jack up the car the sound isn't there anymore...???the car is a '93 GSR...I have no idea what the hell it is....help me thanks.
_justin.
Old Nov 10, 2006 | 11:15 AM
_BEN_'s Avatar
Default Re: Squeaky steering.... (jostins_gsr)
Maybe the steering rack is moving a little bit. And the squeak you hear is it rubbing the rubber bushings.
Just a guess.
Old Nov 11, 2006 | 02:19 PM
jamesc2123's Avatar
The problem is most likely that one or both ball joints are worn. i had this exact same problem on my 92 Si, and that is what it turned out to be.
Old Nov 11, 2006 | 10:24 PM
IsmokeROX's Avatar
it could be something stupid that happened to me if the cotter pins are in at a funny angle on the lower ball joint they rub the brake sheilds on lowered cars which causes a noise the best way to check is to look for a scratch on the sheids
HOMEMADEPOWER
Nov 14, 2012 04:33 PM
JAYB90
Jun 8, 2009 04:47 PM
polyhonda
Suspension & Brakes
13
Dec 19, 2007 08:58 AM
FLCivic
Jul 7, 2003 08:58 AM
dlslvtch21
Mar 6, 2002 02:40 PM
