Suspension & Brakes Theory, alignment, spring rates....
coilover for drag?
Old Mar 25, 2005 | 05:50 PM
CaptainMorgan's Avatar
Default coilover for drag?
Is coilover good for drag racing. I seen a lot of post about coilover, but my buddy was telling me coilover are more for looks. So what is a good drag racing set up. Could i use stock shocks vs aftermarket. I know aftermarket is better, but would just a spring job do the trick???
Old Mar 25, 2005 | 09:40 PM
T4eg's Avatar
Default Re: coilover for drag? (CaptainMorgan)
im using skunk2 1000# on coilovers w/ koni yellows on my turbo car. and skunk2 1000# on stock struts in all motor car. no complients here. Just little rigid ride
Chris
Old Mar 27, 2005 | 10:13 AM
Default Re: coilover for drag? (BlueHatch00)
i read some posts, and it seem like you can run a skunk 2 drag spring w/ their coilovers in the back. But none of the post cover what kind of spring to use in the front. I guess stock shocks can be use in the back right? So my questions what to get for the front.
Old Apr 10, 2005 | 04:35 AM
T4eg's Avatar
IM using 1000# front and rear. Yes u can use them with stock struts
Chris
Old Apr 10, 2005 | 07:08 AM
kidrolla's Avatar
i had coilovers and tokico struts on my car on my car and then i changed them to a dropzone drop spring 2 in drop and know i got to change it back to the coilovers cause it wheel hops like a bia really bad,so bad i ran better times when i didnt burn out and let my tires just spin like crazy.
Throwdown
Jan 12, 2015 03:40 AM
Civic89stdB16
May 4, 2009 12:20 PM
YPT
Suspension & Brakes
Nov 23, 2008 08:36 PM
YPT
Nov 23, 2008 08:08 AM
Tippyman
Feb 2, 2008 06:41 AM
