Suspension & Brakes Theory, alignment, spring rates....
question!
Old May 17, 2005 | 11:22 AM
kr33p's Avatar
Default question!
ok i just recently purchased some omni power lca's. thinkig that by buying this it would fix the problem that i have. im still not sure if it will. ok on to the problem. the problem with my 97 hatch is that it tilts in the front on the driver side more. so its basicaly somthing like this / im trying to get it like this |. well if it wasnt the lca's to change out then could it be shocks? or springs?
and yes my car is droped. i beleive its about a 2' drop..
thanx in advance.
Old May 17, 2005 | 12:13 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: question! (kr33p)
New LCA's will only fix your problem IF the lean is caused by bad LCA bushings, or a bent LCA. If the problem is in the springs or trailing arms, then they ain't gonna help. You may want to get underneath the car & look for any impacts or bent components. Also inspect your bushings and make sure they aren't cracked or distorted...
MaxCody
Honda Civic (2001 - 2005)
Jun 24, 2015 07:46 AM
skylinkata
Jan 7, 2010 06:46 PM
iluvmycivic
Suspension & Brakes
May 14, 2007 06:14 AM
4doorB18Bcivic
May 3, 2003 08:42 AM
