Suspension & Brakes Theory, alignment, spring rates....
Ground Control Question
Old Nov 15, 2005 | 11:55 PM
96golfin's Avatar
Default Ground Control Question
I have a set of ground controls on the oem shocks in my ek hatch,(previous owner) It's now time to change out the oem shocks and i want to know which shocks besides oem will fit over the current ground control sleeves?
When i had my vw with the same set up, i needed to order new sleeves because they couldn't slip over the bilsteins i bought.
Old Nov 16, 2005 | 07:27 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Ground Control Question (96golfin)
I believe Bilsteins are made by Koni (unless I'm thinking wrong). Your Ground Controls will fit over any other brand of shock besides Koni, & Bilsteine. The only problem is that fitting coil-over sleeves to any other brand of shock voids that shocks warranty. Only Koni NA will honor their shocks warranties with coil-overs. And for that to be in effect, you will need the proper sleeves & nuts (gold adjuster)...
Old Nov 16, 2005 | 09:46 AM
96golfin's Avatar
Default Re: Ground Control Question (94eg!)
Thanks, can anyone else confirm this? i wanna make sure since i can't afford to have my car on stands while i re-order parts...
Old Nov 18, 2005 | 09:25 PM
AftermarketCarl's Avatar
Your current ground controls will slide over Tokicos and KYBs.
Old Nov 20, 2005 | 12:45 AM
96golfin's Avatar
Default Re: Ground Control Question (yelointeg)
Thank you.
Which of the two would you prefer (Tokicos or KYB).
Old Nov 20, 2005 | 06:07 AM
Riake's Avatar
Illuminas > AGX
Nonvtak monster
Suspension & Brakes
Nov 26, 2013 12:12 AM
monsteraddict56
Suspension & Brakes
Jan 30, 2011 08:51 PM
BoosterSH
Oct 13, 2003 09:34 AM
Lsubball99
Feb 28, 2002 01:44 PM
Integra187
Feb 1, 2002 09:52 PM
