Using obd2 reader with chrome and obd1 conversion?
Old Jan 14, 2018 | 09:22 AM
ZCcivic91's Avatar
Default Using obd2 reader with crome and obd1 conversion?
I was considering picking up an elm327 and using it with some apps like dash command, more for fun than anything.
One of the cars I wanted to use it with is a 1996 civic with a b16 swap running crome and a obd2a to obd1 jumper harness to the ecu.
Will the elm327 and dash command work with this setup? I’m not sure if the elm unit takes its reading directly from the sensors, or after the ecu.
Thanks!
Old Jan 14, 2018 | 12:04 PM
1999 Civic Si's Avatar
Default Re: Using obd2 reader with chrome and obd1 conversion?
The OBD2 port doesn't work once you convert to an OBD1 ecu (jumper harness or not), I believe AEM stand alone can still use the OBD2 port, but it doesn't read emissions monitors, so I don't even know if that would work for you are wanting too do. I know Hondata S300 v3 allows for Bluetooth connectivity.
Unless something has changed recently and crome allows this feature, I don't think you will be able to do what you want with the elm327.
Old Jan 14, 2018 | 12:38 PM
ZCcivic91's Avatar
Thanks for the answer, disappointing but kind of what I expected.
thanks!
uses0ap
Feb 17, 2009 01:16 PM
NOman0608
Jul 26, 2007 10:28 AM
3s0n3
Mar 8, 2006 09:42 AM
shawnc21
Jan 9, 2003 11:21 AM
Gmedalion
Jul 10, 2002 07:56 AM
