92 accord code 43
Old May 31, 2017 | 07:36 PM
Kyleinthahonda's Avatar
Icon5 92 accord code 43
I have a code 43 (fuel system) the engine seems to be minorly misfiring especially when not under acceleration (cruising). It seems to me like the fuel injectors could be contaminated. Anyone had a similar issue or know what this is? Would like to get a second opinion before I take the injectors out.
Thanks
-Kyle
Old May 31, 2017 | 10:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 92 accord code 43
Pull the ECU fuse and memory back-up fuse, wait a few minutes, then re-insert them and crank the car. If it seems to run fine... the problem is your O2 sensor. Replace it. If it still runs like crap as before, you will need to see where the problem is. Lack of fuel makes the car misfire... so it could be a clogged fuel pump pick-up, clogged fuel filter, or clogged screens at each fuel injector. Also, a bad fuel pump could be sending lower than normal fuel volume, reducing fuel pressure, and thus... leaning out the engine.
rbizzell30
May 9, 2009 04:27 AM
thatnikkashoD
Feb 23, 2008 08:54 PM
cincispeedemon
Nov 22, 2004 05:51 PM
IwanAturBo
Mar 16, 2003 06:53 PM
blackcracker
Oct 25, 2002 06:13 PM
