VTEC CONTOLLER
Old Mar 20, 2018 | 12:32 PM
Cesar84's Avatar
Post VTEC CONTOLLER
Ok I need some help, I got a 00 civic si with I/H/E, when i bought it came with a crappy vtec contoller called Precision Vtec Controller. I was plan it to remove it cause I have no need for it? Can you guys tell me the easiest way to remove it? it just started to act up and jump my vtec engagement points around......Id apreciate it thanx!!!!!!!!
Old Mar 20, 2018 | 03:30 PM
motoxxxman's Avatar
Default Re: VTEC CONTOLLER
honestly, no offense, but if you have to ask, you should probably pay a shop to do it. It requires some quality wiring, and knowing how to do it from experience in order to do it properly, or you could cause a lot of damage.
Old Mar 20, 2018 | 05:54 PM
Cesar84's Avatar
I know the basics of wiring, if you can pin point what I have to do I’ll apréciate it
Old Mar 20, 2018 | 08:22 PM
TheShodan's Avatar
Moderator
not all controllers are wired up the same. You have to find the original installation manual and schematics in order to be able to remove it yourself
Old Mar 21, 2018 | 05:07 AM
motoxxxman's Avatar
typically, you need to remove all aftermarket wiring, and look at all the stock wiring colors and reconnect any stock wires that were cut. And it needs to be soldered and well insulated.
If more than one wire has the same color scheme, that's where it gets fun because you'll need to look up wiring diagrams for your car and figure out which wire needs to be reconnected to to which wire.
xxghettothixxx
Jun 28, 2007 07:10 PM
CimorelliCRX
Nov 1, 2002 02:41 PM
