Best MAP sensor for 1.5
Old Jul 1, 2017 | 07:44 PM
moto44's Avatar
Default Best MAP sensor for 1.5
We are racing a 86 civic with a 1.5 on a 1/4 mile oval asphalt track and must be 100% stock. I believe the MAP sensor is bad and need to replace it. the original OEM one cost 250.00 . Could i use one from a later model that cost less?
Old Jul 1, 2017 | 08:51 PM
TheShodan's Avatar
Moderator
Default Re: Best MAP sensor for 1.5
junk yard, or a wrecked civic from 1990-2001. They are all the same Denso MAP sensor
Old Jul 2, 2017 | 08:41 AM
moto44's Avatar
Are those 3 pin or 4 pin?
Old Jul 2, 2017 | 08:55 AM
spAdam's Avatar
Loved
Community Favorite
Show a picture of what you have. A lot of us here aren't terribly familiar with the older engines.
Old Jul 2, 2017 | 11:56 AM
moto44's Avatar
Here is the pic if the stock one
Old Jul 2, 2017 | 03:18 PM
TheShodan's Avatar
Moderator
ohhhhh... That's a different animal altogether from the other D/B/H/F series that were the standard.
*Edit* I just realized it was from a 1986 MAP sensor. That's OBD0. You're better off going to the junkyard as I stated. .. Sorry about that. !
Old Jul 2, 2017 | 07:25 PM
moto44's Avatar
so later model 3 pin one if wired in right wont work?
Old Jul 2, 2017 | 07:51 PM
TheShodan's Avatar
Moderator
That one you'll need to try on your own. If it has the right voltage signal for your ECU, sure. If not, nope...
No one really deals with that OBD0 from 1986.. Not even me, and I'm OLD..
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
baulum
Apr 13, 2008 10:18 PM
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
quickhondaz
May 23, 2007 02:34 PM
