Obd2b to obd1 d16 HELP
Old Oct 24, 2017 | 07:56 AM
Mad_Mikey's Avatar
Default Obd2b to obd1 d16 HELP
Hi all struggling really need some help im desperate. I bought ej6 coupe cheap that ran but would not rev past 4k. I did not have keys and immobiler light was on. So... i decided to go obd1 po6 de immobilized and jumper harness as i had this sitting around. Now i have changed 3 wire to 2 wire iacv valve and now changed to obd1 distributer! Done that but it is not revving properly has a mind of its own! Now the two plugs that are the same size match from obd1 to obd2b. Now there is a second small plug on the obd1 distributer that has 2 wires 1 blue and the other 1 is black and yellow, i left the small plug alone and tried starting it and didnt run. So there was a bung on the obd1 plug the connected to black and yellow car side. So i connected the black and yellow from the small plug to the car side and it ran but still had a mind of its own. Now the thing that is annoying me is i do not no where the last blue wire on the small plug from the obd1 distributer goes??????? Sorry for essay. If any body can help i will buy you a drink!
Old Oct 24, 2017 | 08:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Obd2b to obd1 d16 HELP
The blue wire from the OBD-1 distributor 2-wire plug is the tachometer output wire. It is not used on '99-00 Civics because the tach signal is sent from the ECU to the instrument cluster instead of coming directly from the distributor as the older Civics do. If the engine runs and you do not have codes for any of the position sensors (TDC, CKP, CYP or CKF)... then the distributor is not your problem.
Last edited by JRCivic1; Oct 25, 2017 at 09:56 PM. Reason: Bad sentence structure... embarrassing.
Old Oct 24, 2017 | 09:01 AM
Mad_Mikey's Avatar
Hi i no that mate and at the minute i have not received my obd1 reader. But the obd1 ecu uses that blue wire and i do not no where to connect it. The obd2b did use the ecu but since ive swapped to obd1 i need to connect that last wire to somewhere and i do not no where to connect it
Cheers
Old Oct 25, 2017 | 09:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You can connect it directly to the tach input wire on the back of the gauge cluster OR connect it to the tach signal test wire/port on the left side of the car near the shock tower. It is a blue wire with silver bands... likely pushed into a black rubber holder taped to the chassis harness.
Momentum
Aug 13, 2010 07:11 AM
5 Skware
Aug 4, 2003 03:07 AM
5 Skware
Jul 30, 2003 03:28 PM
5 Skware
Jul 30, 2003 04:38 AM
