Car not starting after installing hondata 4 bar map sensor
Help Guys,
After I installed hondata 4 bar map sensor my car does not want to start. I have selected Hondata 4 bar map sensor inside the hondata software, I have also try changing the settings back to stock map sensor and it still does not turn on. When I plug the stock map sensor it turns on without any problems. The hondata map sensor is brand new. Can you guys please help me out? Thanks I appreciate any help
Re: Car not starting after installing hondata 4 bar map sensor
Can you see any signal output from the sensor in your SManager datalog? Have you tried testing the sensor? Wouldn't be the first time a sensor was bad right out of the box.
Todallybuilt
Engine Management and Tuning
10-15-2017 06:18 AM
b20turbocivic
08-12-2010 07:06 PM
