92 civic fuel problem
Old Aug 23, 2017 | 07:31 PM
baglyfe478's Avatar
5 Year Member
Default 92 civic fuel problem
I have a 92 dx civic i have a problem with burning too much fuel but its not running rich. What i mean when i say that is i am only getting around 180 to 200 miles per tank and i should be getting well over that with a stock d15 engine and manual transmission. I jad some wiring issues to work out when i first bought the car. Also note that the 92 dx has a map semspr mounted on the firewall. So i fixed all my wirimg issues and running on the stock p06 i have no check engine light or codes. I swapped the dx throttle body to a ex with the map sensor on the tb. Still no codes. But i am burning alot more fuel than i should be. Any suggestions on what to do about this? Is there a certain map sensor i should run besides the ex that will bolt on to the tb itsel or should i go back to the firewall map? Thanks
CXHBumpin39
12
Jun 7, 2013 05:41 PM
Munkeyd00d
Oct 3, 2011 07:20 PM
Discretely elite
Sep 25, 2006 02:28 PM
civic_sedan
Aug 26, 2002 01:40 PM
