Assist Needed: management choice for turbo F22B
Hi all. Don't know if I'm posting this in the correct place. But I have a 1997 Honda Accord Coupe 2.2 F22B5 2.2 sohc non vtec and I've turbo'd it. A question I'm looking to see if any of you guys can help me out i'm unsure what ecu I will need to run?? Many Thanks
re: Assist Needed: management choice for turbo F22B
You can run it on a multitude of ECUs. I'd recommend something that gives you good control of the fuel and ignition tables. Technically you can do it on a chipped ECU, but I don't trust those things as they're only base maps and aren't dialed in for your specific setup (you're more likely to knock in boost). I'd recommend at least a S300. The more money you spend on it, the more adjustability you'll have. Also, you'll either need to learn how to tune or to find a reputable tuner who knows your EMS in your area. The availability of tuners that can tune your ECU (or how much time you're willing to invest into learning how to tune) should also be a major deciding factor.
