Open loop tune coming to a close!
Old Apr 12, 2017 | 02:23 PM
Txdragon's Avatar
Default Open loop tune coming to a close!
Nearing completion of my open loop street tune. Still logging and adjusting, but I'm about done now! My goal is to get all my cells to +/- 9% or less. I'm finally close! There's still some WTF areas that seem to be a right pain to get rid of, like the 70% rich cell.. sigh.. Anywho.. I'd say about 2 more log/adjust sessions should put me where I'm attempting. Then it's closed loop time.
Old Apr 12, 2017 | 02:41 PM
pogeeboy27's Avatar
Default Re: Open loop tune coming to a close!
**** that's painful to read. You mind taking using the print screen key to take a screenshot and reposting?
Old Apr 12, 2017 | 03:33 PM
Txdragon's Avatar
Lol, my bad. If you're looking on mobile, zoom in on the screen. I'll see about fixing it otherwise!
Old Apr 12, 2017 | 03:50 PM
Txdragon's Avatar
Now it's fixed.
Old Apr 12, 2017 | 04:13 PM
80%downtime's Avatar
If you know the likelihood of you being in those areas of the map on street are going to be slim to none, you might be better off just shaving the number to what you suppose the value should be and letting the closed loop handle it from there. Hitting those areas of the map on street isn't exactly the most feasible thing to do.
Old Apr 12, 2017 | 04:23 PM
Txdragon's Avatar
Took me about 10 map reloads to figure that out. Lol! Overall I'm happy, even as it is. This round will be my last for open adjustments then tomorrow I go closed loop. I'll start tweaking timing at that point, seems ok now really.
Old Apr 13, 2017 | 04:07 AM
spAdam's Avatar
Loved
Community Favorite
+/-9% is a lot of error! The terribly simple lambda control is going to have a tough time with that and you're going to to be running around with a ton of fuel trim. Try to get it more like <3% total error with nothing negative (so, 0 to 3% rich). Don't worry about cells you can't hit or cells that have huge outlier numbers. Use your best judgement to extrapolate those cells.
I rarely touch the first column from base (you should be in fuel cut there) and I make my last column the same as my last achievable column. These two end columns are there to keep you "on the curve" and keep the ecu from extrapolating. Look at the 2d view of the map and note any points that increase/decrease a lot between rpm breakpoints. Add a column between those two breakpoints for more resolution interpolate the new column and rerun as needed.
Make sure you don't have any rows crossing and smooth as needed. Check the 3D view and smooth some more. Rinse and repeat and THEN turn on the lambda control (closed loop)
Old Apr 13, 2017 | 04:39 AM
Txdragon's Avatar
Thanks for that! I didn't think it would be that much error at +/- 9%. Now thinking about it, yeah, I suppose. Still getting closer though!
Old Apr 13, 2017 | 09:51 AM
I'm not familiar with neptune, but I'm going to go on a limb and presume that there's some way to datalog the car in closed loop and view the percentage corrections the ECU is making at those areas in the table. Just reapply that percentage to the raw values in the table, and you should be able to dial in without forcing yourself in open loop. This should be done on a dyno because if you're zipping through the cells and just trying to tap them as you pass them (on street), tip in fuel compensation may be present in the readings and throw off your entire calibration.
Old Apr 13, 2017 | 10:23 AM
spAdam's Avatar
Loved
Community Favorite
Neptune shows you the percentage you are off. That is what his pic is showing. Doing it the closed loop way would be significantly more painful.
I agree, doing it on a load bearing dyno would be far and away the most efficient way to do it, and is also the only real way to tune part throttle ignition. I can almost guarantee that those 29 & 70% rich cells are tip-in related errors based on their locations.
Also, start tuning in lambda instead of AFR and your life will be easier. Your error from target is always in %!
Old Apr 13, 2017 | 12:14 PM
Txdragon's Avatar
I log my runs to and from work. It's about a 30 minute drive one way with a good mix of cruise and highway with some hills thrown in. When I'm cruising, I keep steady on the throttle for as long as I can over certain areas so I can get a good read for those cells. I understand a dyno is better by far, but this is all NA for now, plus the nearest tuner that handles Neptune with a dyno is over 3 hours away and charges 150 an, hour 3 hour minimum.. When I install my turbo setup, I'll consider that a bit less prejudicially.
Old Apr 13, 2017 | 12:19 PM
Txdragon's Avatar
I haven't considered lambda tuning vs a/f. Now that I know I'm still painfully off, I'll consider that.
Old Apr 16, 2017 | 12:28 PM
Txdragon's Avatar
A couple runs after installing the new clutch has me near dialed in this time. I am now with a small number of lean cells and rich cells are average 4%. Tons between 1 and 3, several 4 and 5.
I have been playing around with timing as well. From my understanding, I should be shooting for 29 deg at WOT with 13:1 a/f and I am close at 28.5 lol. Feels great and new clutch is certainly putting it all to the wheels now, no more slipping!
CplNet
Engine Management and Tuning
Jul 3, 2013 06:29 PM
bnmm
Jan 3, 2011 11:13 AM
Projectludatic
Mar 5, 2010 05:50 AM
aasarsak
Mar 22, 2009 10:17 PM
lanceh
Jun 19, 2002 07:26 PM
