Aem series1 1020 offline Issue
HI everyone,
Same computer same USB to rs232 adapter i always i quickly connect my ems now start offline connection problem I can't connect but i have Aem serial Guage serial Guage work with Ems no problem. I format pc win10, win8, other serial USB adapter I try not connection always offline
re: Aem series1 1020 offline Issue
Run the AEM program in administrator mode. Also, update the drivers. Check AEM's website for the drivers. If that still fails, make sure that your ECU is grounded properly, otherwise it won't power up and you'll always get an offline connection.
Re: Aem series1 1020 offline Issue
Thank's for Answer, I'll control again all
See if you have the proper drivers installed with no overlap from other drivers. Also, try different USB ports on the computer. I can't remember exactly how I did it, but I had this problem in the past and unplugging and replugging the USB during the ECU detection process did it for me.
Today I try other labtop I think my labtop problem
SpeedDreamz.com
03-18-2004 07:51 PM
