General question: How does Engine tuning actually improve its performance?
Old Nov 8, 2017 | 07:15 AM
Vtec04's Avatar
Default General question: How does Engine tuning actually improve its performance?
Probably a dumb question, but how does tuning an ECU increase power? As far as I know, the ECU goes into “maximum power” mode and ignores fuel efficiency at full throttle anyway. Am I right? I understand that tuning will improve throttle response at partial throttle by constantly running rich at the expense of efficiency, but it runs rich at full throttle anyway. Thanks.
Old Nov 8, 2017 | 07:48 AM
1HGEJ2's Avatar
Default re: General question: How does Engine tuning actually improve its performance?
lean fuel..incrasing ignition, make power. u dont have this on stock ecu.
Old Nov 8, 2017 | 07:53 AM
Vtec04's Avatar
But if full throttle performance could easily be way better just from tuning, why wouldn’t they tune them for gas mileage at part throttle like they do, but tune for maximum performance at full throttle from the factory?
Old Nov 8, 2017 | 08:40 AM
2x0's Avatar
2x0
10 Year Member
Two main reasons
- Factory tunes are universal and do not account for variations in each individual engine build. Therefore they have added safety factor built in.
- They do not tap every bit of power because they favor longevity of the engine.
So in most if not all cases, there is more power to be made by tuning timing and fuel for what a specific engine needs, and maximizing its potential.
Old Nov 8, 2017 | 08:48 AM
Vtec04's Avatar
Originally Posted by 2x0
Two main reasons
So they may, for instance, build an engine that can make 150 HP, but they may intentially limit it to, for example 130 HP with the factory tune? So how much power can be made by tuning the timing and running on 93 octane, and how much power can be made by adjusting the A/F ratio? Thanks.
Old Nov 8, 2017 | 10:41 AM
2x0's Avatar
2x0
10 Year Member
There is no way of knowing without going and getting tuned. Every engine is different.
Also glad you brought up 93 octane. Car makers have to take into account the crappy gas you may get some places, another limiting factor. Then there's substandard aftermarket replacement parts, such as ignition components, filters, and the variables go on and on.
Old Nov 8, 2017 | 12:56 PM
pogeeboy27's Avatar
Good reading for tuners
Qveon
Aug 10, 2006 11:31 PM
aZnjCC
11
May 23, 2006 01:39 PM
bennnjamin
Oct 23, 2003 06:49 AM
Quick 200k Mile Motor
Jan 25, 2003 04:00 PM
shamoo
Jun 18, 2002 12:07 PM
