Dumb Question about DYNOTUNING
Old Aug 12, 2017 | 08:25 PM
Chemi421's Avatar
Default Dumb Question about DYNOTUNING
Hey Guys,
I have a dumb question. Does the tuner need to know what mods are in my car in order to optimally tune it? Or will his computer and gauges just tell him everything he needs to know?
Like.. if my car has forged pistons/rods, does he need to know that since he can't actually see it??
Thanks!
Old Aug 12, 2017 | 08:46 PM
toyomatt84's Avatar
Sanji
Default Re: Dumb Question about DYNOTUNING
Tuners will typically start with a rough baseline, utilizing a broad idea of what components you have. But, in all reality, they're going to tune it off of fuel ratios, timing, etc.... Whether or not you have replaced pistons/rods, won't really matter. They'll be pulling data from the sensors available to them.
Old Aug 13, 2017 | 11:40 AM
Chemi421's Avatar
So.. how does forged pistons and rods actually increase horsepower? Like i get intake/header/exhaust/more fuel can increase power due to more airflow/fuel, etc. But then how does forged internals help the tuner get more power out of the car? how does that affect air & fuel ratios and timing and stuff???
Old Aug 13, 2017 | 06:55 PM
ThE HeLLRaZoR's Avatar
They should not need that info. But it's ideal for them to know.
I like to know stuff relating to; rotating mass, piston shape, combustion chamber, Cam specs,
Old Aug 13, 2017 | 07:31 PM
motoxxxman's Avatar
Actually, the tuner does need to know all modifications done to the car. Because that's not only how he creates a basemap, it's also how he determines what the safety level of the engine is for what power he can get to without worrying about catastrophe as a general rule of thumb.
For example, pistons and rods don't create more power (except when going much higher compression than stock), they simply allow the engine to not break at high power levels. If the engine is sleeved and has all forged internals, and the customer wants around 500hp, the tuner knows that could be easily possible. But if the customer wants 500hp, and the engine is stock internals, hell no the tuner won't even think about attempting that.
If someone gives a car to a tuner with zero info, and says make as much power as possible, expect to get a dyno chart with a lot of power, and then a big dropoff because it blew up.
Old Aug 14, 2017 | 03:01 PM
1HGEJ2's Avatar
right!!!
Old Aug 14, 2017 | 03:03 PM
xactdyno's Avatar
totally true! the only way to know reasonable limits is to know all the parts that aren't stock.
if it's all stock, then i think this route.
"x" mods, then i factor that in.
and no, just looking at the sensors or data doesn't tell me everything.
for instance if you put on an omni 3 bar map and didn't tell me, i'd know something was up because the map isn't reading where i think it should be but there's also and omni 4 bar. and you can get kinda same results in the data by having tps and map plugs swapped.
tell you tuner all you know about the car.
MikeChally
Nov 10, 2011 03:27 PM
homicydalboy
Apr 12, 2007 01:14 AM
krazydbiker
Mar 24, 2007 02:24 PM
phatrick2332
Aug 12, 2003 02:36 PM
