Is it possible to run A Hondata Prepped K20 ECU on a K20A6 Engine Harness w/ no tune?
Hi Guys
im new here, but was hoping to tap into some of your expertise for a problem thats started driving me a bit nuts.
i decided to put a k20a6 into a suzuki samuri, the logic being i wanted the lower torque and fuel efficiency of this motor, plus its like double the power and torque of the standard suzuki engine
problem is, i have now installed all the hardware, the engines in there, custom flywheel, engine mounts, radiator, gearbox adapter plates, its basically finished, except for the ecu
i have the stock ecu for the k20a6 honda accord 2003, but now im trying to remove the immobiliser..... seems no one can do it.
so i was wondering, hondata do fully programable ecu for civic type r and integra etc, the ecu has identical ports, if i buy a hondata type r ecu, will it work with the k20a6 harness/engine?
i guess my main concern is that, even though the ecu ports are identical, that actually the wires are inputted differently, and ill blow the hondata ecu
alternatively, i thought about betting a engine harness/loom from a civic/integra and modifying it to fit the k20a6 engine, but this seems like a longer solution
anyway, if anyone has any advice, that would be greatly appreciated
thanks in advance
thanks in advance
Moderator
Re: Is it possible to run A Hondata Prepped K20 ECU on a K20A6 Engine Harness w/ no t
From what I recall from Hondata, you cannot disable the immobilizer by simply using their hardware/software interface.
The purpose of using these systems is to get a custom tuned setup, and not just to be used to bypass key security systems. This is expected to be tuned/mapped.
https://www.hondata.com/help/flashpr...l?features.htm
I've seen several ECUs that are not on the standard list (like your Accord) be sent to a Hondata dealer to be prepped and calibrated, but not swapped to have it's immobilizer removed.
Having said that, your best bet is to contact Hondata, or a Hondata dealer to see other options, after you've seen their support site and gone through their Hondata forums.
https://www.hondata.com/technical-information
In order to not have an immobilzer at all, you must substitute then entire system for a standalone, such as an AEM EMS, Haltech, Motec, Autronic, MicroTech, etc.
Please put a location/region in your user profile so that we know what markets are available to you to help further in other topics, please.
vy3tnamezz
Engine Management and Tuning
09-20-2009 10:43 AM
