How do i install my Hondata4Port Boost by gear solenoid. CONTROLER two wires?
How do i install my hondata 4 port Boost by gear solenoid says MAC on the solenoid. I have the fittings and i know where to mount those.. But the two wires where do i mount that? the two wires are black. and no instructions on where to mount the wires?? i need help and want to make sure i do it right.
i have a 1995 civic vx with my ECU is a p28 HondataS300V3 says built in boost by gear?
where do i mount these wires both black wires. do i mount the boost by gear with the extra wires sticking out of my hondata s300v3 aux. wires? or how can i insall this i wanna make sure i do it right...
need help thanks….
need help thanks….
Re: How do i install my Hondata4Port Boost by gear solenoid. CONTROLER two wires?
i loacted A11 on the ecu pins on my ecu. I've connected one wire from the solenoid soldered A11 ok. since its not used i didn't t into it i just put it one wire.
the next I've looked online for the wiring for the other voltage. i currently have a civic vx some guys online and youtube used the A25 in ecu.
but my question is that is it okay that i use it.
i bought a kit from ry wire that converted my 5 wire o2 to the 3 wire o2 kit. that A25 is already tapped into for my O2 sensor?
for my solenoid should i use another source or can i use the same tapped soldered wire A25 as with the o2 conversion???
please lmk. i don't wanna make a mistake.. the A25 is already tapped.
thanks in advance….
Ecu needs to have the pwm components installed to work. For a p28, one wire to a11, the other wire to a 12v ignition source. I just tapped into my fusebox where my gauages are ran to.
what fuse did u use your fuse box?? ….
please let me know thanks...
B20EF
02-22-2008 04:44 PM
