Hondata causes Car to "bog" after skunk2 Intake Manifold Install
re: Hondata causes Car to "bog" after skunk2 Intake Manifold Install
You're shifting the powerband be using shorter runners. If you want more low end power, stick with your gsr manifold or get a charger.
I like the tuna here
Something is probably messed up on the basemap, I'll repeat what motoxxxman said, you need to get it tuned. Or just drive on the stock ECU.
Mikex25
11-05-2001 08:14 AM
