obd2a ecu, odba interior loom, obd2b engine loom problem
Hey lads need a hand here with a build I'm doing on a ek civic. I have a obd2a interior loom and a obd2a spoon ecu that I would like to put with my obd2b engine and loom is it possible to get a harness for this if so what type do I need. Any help appreciated
Re: obd2a ecu, odba interior loom, obd2b engine loom problem
Look for ffstech's pictures of OBD2A and OBD2B pinouts. Put the pins on your OBD2B connectors where they correspond to the OBD2A pins and you'll be fine. Otherwise, buy a rywire harness, splice the proper wires and get it over with.
That sounds like a lot of work... how about sourcing a '96-98 OBD-2A engine harness, install it on your engine, make any minor wiring changes necessary (distributor plug and maybe IACV depending on harness version) and simply plug it in inside the cabin.
BbOi0420
11-28-2014 10:40 AM
nycpatron
02-25-2010 07:53 PM
