Assistance Needed: Apexi Power FC on B18C1
I just bought a b18c EG with the power fc edu, i have to open the throttle to over 1000rpm to prevent the engine turnoff, if i release the padel while it is 20 km/hthe engine must be turn off. And the new spark plug become to block after the idling. So, i think the mixture is rich. And check the injection map on the commander , that all the data are "50", i dont know what does it meaning. Is it the correct data?
should clear all the data and do the self learning?
Anybody have the b18c with apexi same here? Can give me some advise? Or some data ? I just want it can run in normal. Thanks you!
Moderator
re: Assistance Needed: Apexi Power FC on B18C1
Depending upon the year of your FC, you may be able to use the FC DAtalog IT software, or go to an Apexi.tuner to manipulate the entire tables of the software.
You can't just use .hdx map formats without access to the full table. You don't just go around like hondata or AEM and get a "bunch of maps"
Is this NA? as the EK9 b18c can run by itself. But only if your TPS sensor is calibrated to run stock with stock injector.
I know it works. I'm still the only one in my region of the U.S running Power FC & turbocharged. Been doing so since 2004.
Re: Assistance Needed: Apexi Power FC on B18C1
Find someone with Datalogit FC software and box ( was very popular amongst the RX7 FD crowd ) . or you can buy one from new zealand.
You will have better access to the maps, and be able to tune the afrs as needed.
FC Datalogit - Tuning Software for your APEXi Power FC
even though I find power fc outdated, it still works great.
Moderator
So, which hardware/software you use depends upon the year your FC was made. If it wasn't made in the last 3-5 years, you'll need FC datalogit. If you purchased it recently, it means that you're using the .hdx format, and can use the FC Commander Pro Sfotware (415-X910). You cannot use the FC Commander Pro Software on older Power FCs earlier than 2009. That's where the Apex'i Power Excel Dealer /tuner comes in.
I'm changing to Haltech in my Integra and have a newer Power FC (.hdx) format for my wife's car, so as Soon as I change out the hardware, I may sell the Datalogit and older hardware.
Brembomaster
Engine Management and Tuning
04-10-2018 06:23 PM
