Kpro in 2008 Element help.
Old Jan 7, 2018 | 06:05 PM
BongoBennie's Avatar
Default Kpro in 2008 Element help.
I want to run KPro in my 2008 Element. It has VSA and ABS. I don't mind losing the VSA (I assume it resides in the ECU?) but does the ABS system work on its own or is it integrated somehow into the ECU? K24a8 has electric TB fwiw.
Old Jan 12, 2018 | 08:55 AM
Spunkster's Avatar
Default Re: Kpro in 2008 Element help.
This cannot be done with drive by wire.
Old Jan 12, 2018 | 10:10 AM
Correct and that’s why I mentioned it, the good thing is it DOES have throttle clables since the pedals never changed with the throttle body. Converting the engine isn’t the issue it’s understanding how the VSA, ABS, and ECU are connected....... I’m going through all this because I want to run E85 censor...... I also/rather want it for my 08 Fit Flashpro, (I’m that guy).
Cruiserdude
May 13, 2019 08:20 AM
RacingMeerk@at
Honda Civic (2001 - 2005)
Jan 2, 2011 10:35 AM
blykins
Nov 11, 2002 12:13 PM
DC5 Type-R
Apr 21, 2002 06:15 PM
Greyout
Jan 24, 2002 02:16 PM
