Please help!!!
Old Jun 17, 2017 | 03:01 PM
Jason Long's Avatar
Default Please help!!!
Need help. I have Acura Integra. When I first started up when it's cold it runs fine after it's warmed up and I started back up after sitting for only a half hour it will only start if I press the accelerator then runs real bad for a couple minutes then will return to running normal if I shut the engine off and started right back up it runs fine just only after sitting for about a half hour or so. Seemss to only act this way if its hot out side
Old Jun 24, 2017 | 10:46 PM
motoxxxman's Avatar
Default Re: Please help!!!
list of all mods? is it still using stock ecu? basemap ecu? full tune?
isitafox
Honda CR-V & Element
Mar 25, 2011 01:46 PM
Sytar69
Mar 27, 2007 08:43 AM
divingcorners
May 9, 2006 09:34 AM
cr-x si
Sep 7, 2002 04:11 PM
