99 OBD2B to OBD1 Conversion for Automatic D-Series Engine Management Options
Old Aug 13, 2017 | 11:08 PM
Truedeal's Avatar
Default 99 OBD2B to OBD1 Conversion for Automatic D-Series Engine Management Options
Hi I've read a few threads on converting the 99 Civic to obd1.
I understand that one needs a obd2b to obd1 "jumper harness" and in my case I would need one for an automatic.
But I am having trouble deciding which obd1 computer to get for my 99 Civic. I know there are various obd 1 ecu's but which one do I get for a automatic d16zc?
I would like to convert so that I can use bigger injectors to stop leaning out under boost, can't use them with the stock ECUs injector map because it runs super rich in an undrivable matter. Can someone help ?
Old Aug 14, 2017 | 03:04 PM
xactdyno's Avatar
Default re: 99 OBD2B to OBD1 Conversion for Automatic D-Series Engine Management Options
all the programmable obd1 ecus are manual trans only. you won't get them to run an obd2 ecu. you're going to have to go the piggyback route like emanage or similar.
Old Aug 14, 2017 | 03:39 PM
Truedeal's Avatar
oh that is disappointing, what piggyback ECU do you recommend that has good fuel control?
Old Aug 16, 2017 | 06:34 PM
cruizinmax's Avatar
I have setup an AEM FIC in a scion tc and it worked fairly well.
Old Aug 17, 2017 | 07:33 AM
TheShodan's Avatar
Moderator
As stated, AEM FIC, Emanage Ultimate, possibly HP Tuners
Old Dec 3, 2017 | 12:22 PM
Truedeal's Avatar
Default Re: 99 OBD2B to OBD1 Conversion for Automatic D-Series Engine Management Options
Does anyone know If a p06 ecu can control a 99 ek's automatic transmission, because maybe I can replace my P2E-A92 ECU with a P06 before I pull the trigger on a AEM FIC ?
Old Dec 4, 2017 | 07:09 AM
spAdam's Avatar
Loved
Community Favorite
This is your only real option for an obd1 conversion:
https://www.hamotorsports.com/obd2b-...o-harness.html
https://www.hamotorsports.com/neptun...vtec-auto.html
Actorus
Aug 15, 2016 06:24 PM
Nisif
Oct 20, 2012 06:11 PM
95EXcivicsleeper
Jun 8, 2004 07:13 PM
b18bme
Apr 7, 2004 10:43 AM
Patch
Dec 14, 2003 05:20 PM
