Gearing changes vs ECU
Old Mar 15, 2018 | 03:32 PM
BongoBennie's Avatar
Default Gearing changes vs ECU
I have a 2008 Honda Element manual transmission k24a8 DBW, similar to TSX of same years fwiw. I want to add 6th gear and I also want to change FD to 5.4-1. I also want to leave the engine stock with stock ECU. While the speed sensor is not affected, will the speed to rpm differences result in anything weird as far as the ECU is concerned?
Old Mar 15, 2018 | 07:57 PM
motoxxxman's Avatar
Default Re: Gearing changes vs ECU
*Deleted*
my post was wrong, and I learned something new
Old Mar 15, 2018 | 08:12 PM
You can add a 6th to any 5 speed K series trans including awd, very well documented fact
https://www.kseriesparts.com/HON-5SP-2-6SP.html
Old Mar 15, 2018 | 11:42 PM
holmesnmanny's Avatar
only an automatic ecu would need to know what gear it's in, a manual ecu just needs to know speed and rpms for fuel cutoff and a new gear won't affect it
John The G
Dec 16, 2010 05:38 AM
Kipper-Fish
Nov 25, 2008 09:43 AM
