Troubleshooting: Lean Idle Issue
Old Sep 26, 2017 | 09:07 AM
boostedblue23's Avatar
Default Troubleshooting: Lean Idle Issue
So recently I came across a very lean idle reading nothing on the wideband. Replaced the wideband and the wideband o2 sensor thinking that was the case but am having the same symptoms. I also checked for any vacuum leaks, and exhaust leaks before the 02 sensor and everything looks good. Could it be that the primary o2 sensor has gone bad? Any advice and help will be greatly appreciated.
Old Sep 26, 2017 | 09:17 AM
Chance EG's Avatar
Default Re: LEAN IDLE ISSUE
Can you plug a laptop in and see what the readings are there?
What ECU/Tuning setup are you using?
Old Sep 26, 2017 | 01:25 PM
I’m using s300 but when I plug it in I’m locked out of the tune due to the previous tuner
95gsr@530
Aug 20, 2015 02:56 PM
jaysalti
Engine Management and Tuning
Jan 10, 2009 11:58 AM
GTEC913
Jul 1, 2008 02:11 AM
