Diagnostic Issue: P0325 CEL on D16y8
I ha e a 98 civic ex , the d16y8. I keep getting p0325 check engine. I replaced the wireing harness, knock sensor , checked the ecu , still coming on. Any ideas what else it could be?
re: Diagnostic Issue: P0325 CEL on D16y8
Do you get the code immediately after "key on" or does it come on after driving after a short time ??? If the answer is the former, try another known good ECU to see if the problem goes away. In the case of the latter, retard the ignition/distributor timing and try using premium unleaded fuel.
I have to drive it for some time. May take a full day it may take 3 days , it depends. I'll get back with results after everything.
davidclark311
11
09-15-2010 03:37 PM
