D16Z6 ignition issue?
Old Aug 9, 2017 | 07:36 AM
messy.'s Avatar
Default D16Z6 ignition issue?
Hey, just the other day I purchased an EF with a z6 swapped into it. The car had what the previous owner described as "stalling issues" (he originally thought this is a fuel flow problem). What happened was, when accelerating, if the gas was pressed too much, the car would sputter and stall out. If the pedal was slammed to the floor, the car wouldn't rev whatsoever, and just die. I bought new plugs and wires for the car, first threw the wires on in the lordco parking lot and didn't notice any incredible difference. I drove home to my tools and put the plugs in, and the issue was entirely ceased. I drove around the rest of the day, and the stalling issue started coming back. It got worse and worse and eventually I was stuck and called a tow truck. Tried to start it before work this morning with no success. Do any of you guys have any ideas?
EDIT: I should also note that my tachometer stopped working around the same time the car started dying. Occasionally it would spike up but for the most part its just stuck @ 0
Old Aug 9, 2017 | 07:57 AM
theYBLEGAL's Avatar
Loved
Default Re: D16Z6 ignition issue?
TPS sensor may be out of range.
Distributor may be failing.
Old Aug 9, 2017 | 02:03 PM
messy.'s Avatar
just put a new distributor in. this swap is messy, and i had to repin the distributor to uae obd0 plugs. this is how the car runs with the new distributor.
https://youtu.be/Q-dlONG1CDg
embersanenders
Jul 16, 2012 01:30 PM
mish__
Dec 24, 2011 05:30 AM
tpnorth
Jun 11, 2011 03:23 PM
stoicmanatee
May 1, 2011 01:27 PM
Crimson_Tide
11
Aug 17, 2005 11:45 AM
