- Need 400 whp + but undecided
- ep3 ac help!
- WI Backroad Test Ep3 *VIDEO*
- JDM DC5R Rear Sway Bar Bushings
- Where to get my Steering Wheel re-wrapped
- What do I need to convert my 02 to 06??
- EP3 JDM Race Car...Slowly losing power until car only idles when hot.
- Broken Clutch Pedal Bracket
- FML....
- Don Nguyen | Gloss black vinyl roof wrap - White RSX DC5
- RSX Advice
- Ep3 MAF?
- Will LHD RSX HKS turbo kit fit RHD DC5 integra?
- Acura Rsx PLEASE HELP!!!
- 03 ep3 engine rebuild advice!
- '02 EP3- WIPERS stuck on
- Fuel Cut at 5500RPM Base RSX 2003
- Noisy Power Steering DC5 05 Integra
- Civic Type R EP3 NOS fuel feed
- K20a2 full build
- K20A cams in a k20a2 (valve adjusment)
- Ep3 radiator lower mounting post width
- RSX Tranny input shaft dimensions
- Where's the rack and pinion module located
- How well do you know electrical? (Issue)
- EP3: lag/lurch/pops under 2k, rough idle on start, sometimes.
- 6 Speed Tranny with LSD... Racing Headers and RBC Intake Manifold... Or K Pro?
- 2002 RSX Base auto electrical problems
- 2003 rsx
- Newbie with a few tech questions
- Hard starting issue after fuel up
- 02 type s cranks but no start
- RSX EP3 Civic Sway bar
- acura rsx type s 02 oil change
- DC5 Front lip kit
- Buzzing Noise on 2003 RSX type S
- Hesitation
- rear end issues
- icv problems
- Where can I buy single pigtail connectors?
- cel code?
- Hard Clutch pedal
- QP stickers
- Wheel Hub and Bearing
- Starter or alternator?
- acura rsx type s 02 need help with stereo
- 2004 Honda Civic Si with code P0420
- 2002 Civic Ep3 Front Bumper Removal
- Turbo
- 2005 rsx water temp guage??
- what bulb is used on a 04 EP3 JDM CTR Xenon headlight?
- Does skunk2 (sleeve) Coilovers from a EM2 Fit a 04 rsx directly?
- RSX Type S Misfires
- Honda Civic SI 2005 ECT Sensor
- steering wheel interchange
- Dc5r conversion
- Help with OEM LSD install
- Rsx-s convert to type -R
- Turbo k20a3
- These real?
- HELP: Cooling system
- New to the forum.
- KPRO ECU
- Ecu compatibility
- OEM Airbox + AEM SRI?
- Canadian RSX base models
- 2004 civic si EPS
- Radio with no sound
- Need new brake pads for my DC5R Brembo 5 lug conversion
- EP3 Dirty Engine?
- New Motor Idle Help
- Greddy Turbo Kit - Please Help
- ECU
- Buying a used 2002 RSX premium
- ep3 si shut off while driving *help*
- Budget Turbo kit
- RSX S
- (URGENT) Type-s cams and rockers in K20a3!
- 2004 ep3 type r problems :(.
- Radio Code needed 2004 Acura RSX
- obx headers for k20a2
- Coolant Plug Adapter
- Engine oil leak: VTEC solenoid?
- Raceland Coilovers 2002 ep3
- Ep1 - Few Electrical Problems - ANY Help Is Appreciated!
- 02 Civic SI - Paintless dent repair help
- K24a8 engine harness into 04 ep3
- K20 HELP ME TO RECOGNIZE THIS CAMS !!!!
- HELP ME TO RECOGNIZE THIS CAMS !!!!
- S2000 Cluster In 2002 EP3
- 04 civic si hatch headlight
- dreaded lack oem front shock travel, solutions anybody?
- Buying an EP3..Question about stalling issue
- Need help in my ep3s side mirror
- Need some advice on my '02 Ep3 suspension.
- ep3 2.5" coil spring adapter for bearing/tophat
- Steering Shaky and vibrates on higher speed
- 03 Civic Si - rough when wet
- K20z1 into an ep3
- any ep guys relocate battery?
- k20a2 missing oil pickup stuff???
- EPS Problem
- Low Rpm's hesitates and 4 Errors
- Thinking of buying an RSX type S, is this a good deal?
- EP3 Problems
- 2003 Civic Si
- K20A3 with high compression
- Broken Buddy Club Short Shifter.
- 2002 rsx needs more power?
- 2003 Ep3 Civic SRS Light on
- PA/NJ - Anyone want to replace a TCT and timing chain?
- Do I have a a2 head on my ep3?
- Best Civic si to start off with?
- Help! 02 RSX Type-S
- ep3 driver side door wont lock or unlock
- Car stalls after putting in gas ?
- Stock clutch feel in an EP3
- P0172 with multiple misfire codes.
- 06 Si Brake Swap on Ep3?
- rsx base loud knock/tick at 2300-2400 rpm
- S2K Cluster installation for DC5
- F&F TYPE IIs??
- random misfire need help
- Wheels (5lug to 4Lug Swap)
- 7lb/ flash to 9lb Kpro
- After-Cooler
- ep3 vss problem with vtec please help
- Ep3 help!
- found an ep3...but not sure...
- acura parts costly over EP3?
- EP3 issues PLEASE HELP!!!
- Still have knocking sound after a few repairs
- `Rsx tailight
- Pressing wheel bolts; shop or attempt myself?
- Problems with my ep3. HELP!
- Getting a new toy
- EP3 5 Lug Brake Upgrade to RSX-S Brakes
- SRS light: Seat Buckle
- Softer Springs For my ep3
- central locking stopped working ep3 type r, HELP
- Will em2 springs, front and rear, fit on my 2003 Honda Ep3?
- replaced motor now having tranny problems
- Headers DC
- Question about Type S value
- 2002 Honda Civic EP3 16 Inch Tire Options
- Dilemma: RSX Type S spun bearing, killed rod, would like qualified opinions.
- 02 Civic SI pl,a/c compressor, alarm, and SRS light on
- ep3 keeps blowing door lock fuseh
- Issue with new wheels and tires, need help!!
- Good wheel fitment for ep3??
- 02 EP3 with K24a2 head and Type S VT and Cams
- check engine light still on
- i-Vtec to "Real" Vtec? What does this require?
- ep3 power folding mirrors
- (ep3) ebay i-VTEC sticker vs oem?
- Passenger side high beam not working
- Car kinda starts to die when sitting still.
- Civic Si IACV help
- RSX Owners: Seats
- type s tps help !
- Can a type-s exhaust fit a base model
- What suspension out there gives the greatest drop for the EP3?
- New wheels, lowering help?
- 03 RSX-S Gauge Cluster - dead?
- coolant temp sensor?
- ep3 cargo cover part number?
- 05 Civic Si A/C Issue
- Recall for brake booster
- Maintenance: water pump replacement what else?
- Ep3 issues- wont idle smooth and dies at wot
- Buying an rsx-s from a private seller. HELP!
- steel rims
- Ep3 intake
- k24 ep3 problems
- Ride height vs. front toe vs. camber
- retro fitting a rear wing
- car not going over 25mph
- New clutch making a noise
- Finally new brakes!
- New Problem!
- Ep3 Check engine light problems
- Lower Cat Heatshield fell off, now I'm getting warning lights
- 03 Si- pop/thud noise from front pass side
- Good price?
- Suspension bushings, confused new owner
- Honda Integra Transmission Problems?
- 2003 Acura RSX idling and driving badly...Help!
- Shift Boot!
- EP3 suspension help
- 2003 Honda civic hatchback sir side mirror
- 2003 Honda Civic HB SIR Headlight Wiring Diagram
- DC5 K20A3 - Turbo or Supercharger?
- Quick Input Please
- BYPASS IMMOBOLISER ON 2002 CIVIC TYPER EP3
- HID from low to high beam issues
- k20a3 blown head gasket??
- replaced clutch, now its not grabbing.
- IVtech not working?
- Exhaust Pipe to Manifold Gasket
- help k24 ep3 weird issue
- 2005 RSX Noise.... Common Issue??????????
- 2002 Honda Integra K20A3
- Parts to wait off on until or AFTER k20A2 swap?
- transmission on my ep3
- DC5 Brembo part Numbers
- K20z3 in EP3 transmission help...
- dc5 cloth interior
- how to change rack pinion bushings???
- 02 Si multiple error codes causing problems
- bad missfire
- Acura Rsx airbag
- TIRE SIZE HELP
- K20a3 supcharged, kpro CAMS question
- issues with ep3 fog lights install
- NEW EP3 OWNER THAT NEEDS VERY SPECIFIC RIM ANSWERS
- front muont for EP3
- cam on k20a3 worn
- 02 ex front lip on ep3?
- need some info on the k-pro ii
- ep3:? 205/45/16 front vs 205/55/16 rears
- steering column !!!!!!!!
- Name that seat!! ... please
- K20a3 and k20z3 Parts
- mods for my car
- K20a2 transmission 6 speed compatible with k20a3???
- 02 civic SI EP3 exhaust
- So Cal ep3 owner, need help!
- Cam retainer bolt
- ep3: did my motor mount cause this? oil
- Honda Civic Si 2005
- Honda Civic 2002 Si Best Affordable Performance Parts
- Ep3 misfire/hesitation when accelerating.
- engine swap 2005 si k20a3 dead
- Just got a 03 EP3 SI!!!
- Which gas caps are interchangeable for 05 Civic SI?
- What would it take for an EP3 to take on... let's say... an Aventador?
- p1164 and code p1166 please help
- Car idles rough
- 2002 civic si wont start
- helpppppppp. ep3 trans
- EP3 acceleration problem... HELP
- p1298 on 2002 civic si
- Cam positioning sensor BANK 1 after clutch install
- Honda Civic Si 2002 P0420 Code HELP!!
- [How To] Replace the Timing Chain, Guides and Tensioner on an EP3 Type R
- FG4 Suspension in ep3 ?
- 06 DC5 Auto - Weird rythmic pumping/clunking sound when braking for a sharp turn..
- Koni Yellow Install-HELP!!!
