EP3 5 Lug Brake Upgrade to RSX-S Brakes
Hello folks,
I'm currently eyeing a 04 EP3, and I am wondering how much work (and $$) is required to upgrade the car's front brakes to RSX-S specs. I've driven a few EP3's before, but found that the stock brakes are a little lacking.
I've done a bunch of searches on the forum, and I am reasonably certain that this can be done relatively easily. But I can't seem to find a complete break down of the parts I'll need to upgrade, so here is my question:
Since the 04 EP3 already has the 5 lug hub, I guess I would only need the following?
- RSX-S front rotor
- RSX-S front calipers
- RSX-S front pads (from whichever manufacturer)
Does the master and/or slave brake cylinder need to be upgraded as well? Would I need to worry about the brake proportioning, or would ABS take care of that?
Any help would be very much appreciated.
- RSX-S front rotor
You won't see any additional clamping force just from upgrading the calipers/rotors alone. If you want Type S braking, upgrade the master cylinder (has larger piston size) and the proportioning valve must be upgraded also.
Thank you. This is precisely the answer I am looking for.
With the similarities between the EP3 and DC5, I suppose the master cylinder and proportioning valve would be a plug and play affair, right?
Black R
May 16, 2003 03:26 AM
EricUSC
May 1, 2003 09:23 PM
