- First turbo build need help
- K20 won't start
- WOT duty cycle spike
- K20/K24 Timing Chain Problem
- K20 Automatic Transmission AWD
- gear speed 2nd gear set and ebay clutch REVIEW!!!!!!
- EP3 Si (usdm) intake manifold vs EP3 type R (EDM)
- 03 Rsx Type S wont start
- Rpm drops while slowing down
- Looking to Buy a k20z1 rsx type s swap
- Civic SI 2002 VTEC Mulfunctioning P1259
- 2005 rsx type s bad headers?
- 02 EP3 leaking coolant out of hole on engine cross-member
- Power Steering Pump Leak
- Help sticking front caliper
- 06 RSX Type S Starter Grind
- bad ball joints??
- 2003 rsx type s
- Airbag Removal
- BMW Guy stepped into the Honda world some questions
- ep3 with blown head gasket
- Mild K20a2 build...opinions? 230-240whp goal
- How do I make the key in ignition/headlights on warning beeper louder?
- 2002 EP3, 06+ Front, Is FD2 or FA5 Closer
- Codes and Causes! Help desperatly needed!
- 2005 acura rsx
- k20a2 swap into base
- transmission problem, civic 2003 ep2.
- nrg quick release
- K20A 4th & 5th gear part # ?
- Quick question. Ep3 ecu
- Question about my Acura Rsx 05
- Aftermarket cat?
- Do EP3 springs fit DC5?
- installing new lca bushing
- Best Stance Fitment for EP3
- Rear bumping sound at low speed
- how much would it cost
- cruise control?
- rsx/ep3 calipers on my usdm itr 5 lug conversion
- We Lived To See The Civic TypeR Come To The USA!!!
- k20 tuning alternative to kpro?
- Buying a 2002 - 2005 Civic Si
- Shortening stock tie-rods?
- RSX rear alignment?
- Part number for rear Lower Strut bolt?
- Test fit 02-06 RSX for Prototype purposes. Click here.
- 04-05 Type R tail lights.
- godspeed coilovers
- idler pulley bracket.
- High Mileage RSX Type S Questions
- K20a2 head on K20a3
- How to compression test a k20a3?
- 2004 rsx conversion into 2006
- k-series parts.com?
- EP3 Side Airbags... Factory installed, or dealer?
- Help! Popping the horn/stop, hazard, and small lights fuses! Cant drive right now!
- $$$OFFICIAL SPRING CLEANING FS/WTB/WTT Thread $$$
- NEED HELP!!! 04 EP3!!!!
- 04 rsx type s
- How much for a new paint job?
- Door Lock Problems RSX Type S
- "faulty condensor" repair
- p1298 Code - Intermittent ELD Issues?
- Just bought a 02 rsx type s
- what wheels are these
- EP3 no spark no start issue
- ep3 clutch master cylinder
- 03 civic si ep3 no fuel at fuel rail
- ep3 throttle body whistle
- Bad oil pump?
- JDM Integra type R DC5R
- Need Help 2002 Honda Civic Si hatch, idle low, CEL
- Original owners 02 EP3 "refresh"
- wont rev over 3000rpm crank sensor code
- car starts few second. shut off instantly.
- 02' RSX w/ Type R knob
- Can't set TPS within spec
- prc-023 ecu into 04 rsx type s
- Euro 5 door hatch exhaust fitment headaches
- soon
- Can EP3 owners take a look at these wires ?
- CTR Starting Issues
- Need to change catalytic convertor - Recommendations?
- Password JDM Powerchaber with Skunk2 manifold
- help with car
- Seatbelts
- RSX Fuel Filler Neck... does this look normal?
- HONDA CIVIC TYPE R 2003 NOISE
- JDM dc5 type R with Kpro PNF ecu
- rear tire wear issues. need 2nd opinion
- Front end shimmy
- $5800 good price for 1-owner super clean 02' type-s?
- 03 Civic SIR not blowing any air out of heater
- 2003 JDM ITR Brake rotors where to find?
- Idle surge, and running poorly
- Official 2015 DC5/EP3 FS/WTT/WTB Thread
- dc5 auto 3rd pressure switch?
- EP3 K20 engine mount bushing review ?
- Need help
- Valve Adjustment & Timing Chain Tensioner
- what to check for when buying a RSX.
- dc5r header (4-2-1) vs any race header
- Ep3 radiator replacement tips?
- Buying an Acura RSX soon !
- highly delayed acceleration with full throttle
- RSX engine swapped wont crank please help
- k20a2 valve adjustment cleareance
- Wind Deflectors?
- EP3 Rear Caliper Bracket Slide Pin Boots
- 2002 EP3 Suspension Build
- Found an 05 RSX Type S(I think) - few questions
- Problems with lowering my 2002 EP3 ...
- starter trick to remove crank pulley bolt?
- Will I need a torch for rear springs install?
- 02 ep3 suspension help
- EP3 FIX?? Mugen Steering Wheel = SRS Light ON, Brembo Brakes w/o ABS = ABS Lights ON
- no fuel 2004 EP3 civic SI
- *HELP* RSX Type S Interior Lights wiring
- 05 Rsx type s k20a type r engine swap help
- Should I have exhaust made?
- Temp gauge to the full
- dried Chain sound when starts
- Replaced rotor/breakpad but get squealing noise
- acura keyless and switch issues
- a2 reflash with race header?
- inner tie rod removal rsx
- k20a2 swap into an ep3 - keeping the 5 speed - worth it?
- Help me decided my next honda.
- Tein Mono Flex Suspension question
- New to the forum
- Finally got my first Type-R
- Rattle Noise
- Spring rates
- Hondata reflash with bolt on
- HELP WITH KEY ISSUE PLEASE
- EP3 Catback Exhaust Choice
- 6puck ACT installed, now car is slow Help me
- 2004 Civic Si Clutch Replacement
- Dc5R Brembos on 06 Type S ?
- catalytlic converters.
- AC Compressor keeps cutting off
- rsx full ac install
- good buy? 02 type s k20/k24 swap
- Trouble installing Moog Inner Tie Rod
- Civic Type R P0420 code
- Buying 2006 Base RSX.
- Another Turbo Thread
- Random bog
- Where to buy K series parts?
- ep3 k20a2 belt length
- EP3 Seats question.
- B16 in RSX-S
- Alternator fuse burned in high RPM )-:
- ISC N1 Coilovers
- RSX header on EP3?
- K24a2 swap in RSX Type S Problem
- SMOG help/question
- ep3 exhaust
- RSX 2005 doesn't start pls HELP
- Honda Ep3 Help
- 04 civic Si Knocking
- type s stock vs basic bolt on dyno
- Trans won't go in gear
- Ep3 totaled(pics). Need parts!
- engine light
- help! vaccum line off supercharger ?? where does it go?
- Electric Power Steering (EPS) code 16
- Civic TypeR Turbo from Greece
- srs plug:?
- 2003 RSX Driver Door noise when unlocking.
- Short Ram Intake... Where to Buy?
- Quick Questions RSX-S
- Cam Question
- K20z1 supercharger on a k20a2? Possible?
- Detune a Rsx Type S
- high km Rsx Type S for sale
- EDM vs USDM parts
- RSX engine date stamp
- DC sports exhaust system RSX Type S
- Regarding insurance
- DC5 K24 CAI
- soft pedal
- AC/Climate Control Down After Radio Install
- 03 EP3 Lock issue.
- 02-04 DC5 pressure plate question.
- EP3 Fuel Door Cable
- First EP3, with a few concerns.
- Dash lights
- rsx type s rear sway bar
- gt5's on the dc5
- Front bumper reflector
- Solfly's 2002 Civic Si "Ownership Log"
- repair manual
- EP3 Full Throttle Problem HELP!!!
- ep3 srs code
- Good suspension upgrade for daily driver ?
- Loud engine noise in my 2002 Acura RSX
- Need help 2002 si replace fuel pump
- need help wiring in a headphone jack to stock bose amp
- Velocity Stack Mod worth it??
- '04 Si idling at 4000+ RPMs...HELP!
- Help Me!!! Dc5 wont go into gear
- change dc5 oem ecu
- Buddy CLub P1 Racing Pulley Kit Review
- EP3 Cruise Control Light Fix DIY
- Valve Spring Upgrade- School Me!
- Can vtec failure be associated with an engine knock?
- 2005 civic type r
- 218,000 miles used Acura RSX yay or nay?
- Help diagnosing a creaking sound (video inside)
- Is this RSX a good buy?
- clicking slapping noise
- High mileage Acura RSX type S
- Wierd idle, already cleaned IACV - car runs perfect with IACV inlet blocked??
- 04 type s transmission
- Exhaust question?
- 2004 Taillights on a 2002?
- Type r dc5 suspension fitment
- ok brand H geeeks
- Squeak in engine bay during accel/deccel and shift changes
- EP3 stock rim and tire size?
- 1/4 mile help
- 2006 type S idle problems!
- Exhaust fitment
- EP3 CTR dyno run, what you think ?
- Any really good short Header ?
- DIY Custom Emblems/Acetone Wash
- EP3 Power Loss
- Red SRS dash light?
- stock airbox bracket bolts size ?
- WEITEC Lowering Springs rate quastion ?
- RSX THROTTLE BODY FAILURE HELP!!
- Help ASAP!!!! RSX TYPE S....
- RSX SWAP!
- Turbo vs SuperCharger
- Catalytic Converter Replacement
- Cluster Upgrade
- Calling all TECHS: Lets talk trans options
- Type s swap in base rsx
- Anyone know if EM splash guards fit the EP3?
- hi i need help
- Need help w/ PFM conversion – Any help appreciated
- 04 RSX Type - S Code: P2647 (rocker arms actuator a - bank 1 stuck on) PLEASE HELP !
- Constant high-pitched sound
- 02 Civic EP3 Lock Difficulty
- 03 Civic SI wants to die after a full gas fillup?
- clunking noise from front end
- ep3 cranks but won't start?! help!
- Loosing fuel pressure when going up hill
