2004 Honda Civic Si with code P0420
Old Dec 28, 2013 | 11:09 AM
dustinthehawk's Avatar
Default 2004 Honda Civic Si with code P0420
Hello forum members
I have 145,000 miles and have the CEL light on. Periodically, the light goes off..then comes back on. Had the codes read at Autozone and came up with the P0420 code:
Definition: Catalyst system efficiency below threshold bank 1
Probable Cause:
- A/F ratio concern
- Air Leak near H02S (Heated oxygen sensor) bank 1
- Ignition system concern
- Faulty catalytic converter
The car is running great; no change in performance or MPG.
Thanks in advance for any input/advice!
Old Dec 30, 2013 | 03:10 PM
nahonda04's Avatar
Surje.motorsports
Default Re: 2004 Honda Civic Si with code P0420
o2 sensor needs replaced
Old Dec 31, 2013 | 04:47 AM
SickSi99's Avatar
^This. Bank 1 sensor is the front sensor off the manifold.
Old Apr 8, 2014 | 06:55 AM
BigZ88's Avatar
Sorry to bring this back, but I have the same issue. Are the sensors the same, but with a longer set of wires? Seems the only upstream sensors I find are stupidly $$..
Old Apr 28, 2014 | 10:17 PM
BONTY_EP3's Avatar
your cat is done.
Old May 25, 2014 | 12:00 PM
SlowIntegraLS's Avatar
A p0420 means more then likely the car needs a cat. If the car had a faulty a/f or 02 sensor then it would have a defferent DTC then the p0420. The car trips that DTC when the computer doesn't see a big enough change between the primary and secondary 02 sensor readings. Now if the car had a p0420 and another code for the 02 system then I would start with the sensor. the faulty sensor may trick the PCM into seeing a faulty cat. But since there is only that single code it is safe to say your cat is bad.
Old May 25, 2016 | 09:28 AM
HerrFunf's Avatar
Hi guys, long time Honda enthusiast, first time poster..
My FRS got totaled by a dumb kid a few weeks ago and I've been craving another naturally aspirated high revver... so... Honda.
I just drove a 2005 civic si and was taken back by how slow it was. After watching acceleration vids on youtube, I think this car was much slower than it should be. The CEL was on and the two codes that came up were both catalyst related, one of them being P0420, I forget the other one.
Question is: Would a bad cat really be hurting the acceleration that much?
There wasn't a drop of oil anywhere on the lower engine or trans, car was right around 100k, seems pretty well taken care of, maybe needs new cat AND tune up? I could feel vtec hit somewhere around 5 or 6 grand, but just not very strong.
dumars
Sep 28, 2017 08:07 PM
crx2hatch
Feb 10, 2011 06:30 AM
redm3turbo
Dec 17, 2009 08:25 AM
BobCT
Dec 21, 2005 06:06 AM
