PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. odd shaking / roughness in reverse WHEN COLD
  2. think i figured it out
  3. Need Ideas for ep3 Build
  4. RSX Type S Suspension Question
  5. K20a2 6speed tranny how many quarts off oil
  6. Weapon R secret intake for 2002 rsx base
  7. 07 and up civic si trans
  8. Looking to upgrade my 2002 rsx base
  9. Radio Code Acura RSX
  10. EP3 Brake issue
  11. Passenger Side axel help on ep3
  12. Engine Rebuild Gone Wrong.
  13. 03 RSX strange noise when taking off
  14. Idle Problemo
  15. New Year means new video with the Civic Si
  16. aem best intake?
  17. 03' rsx type-s rebuild =]
  18. My ep3 build need opinions..
  19. Are RSX/EP3 Cold Air Intakes the same???
  20. Need Help With Brake Pads
  21. Need Help With GC/Koni Install on Ep3
  22. K20a2 Valve Spring Question
  23. Dash harness plug question
  24. Crown Royal shift boot
  25. 05 ep3 shift boot.....help
  26. Ep3 with door unlocking problem
  27. s2000 wheel in ep3 with ep3 airbag?
  28. 2004 Rsx Type-S, maintenance required light
  29. choosing witch tein springs to get
  30. New EP3 owner: painted center consoles?
  31. Looking into buying 05 rsx type s -HELP-
  32. Ep3 HID conversion harness
  33. 04-05 hid headlight
  34. RSX Hood latch problem
  35. 02 rsx-s reviews?
  36. 2005 Sport Keyless Entry
  37. EP3 center console/arm rest?
  38. busted engine that needs a swap what do i do?
  39. buying JDM parts for my RSX at a good price
  40. Turn signal & hazard are intermittent
  41. DC5 cel code p0134 & p2227
  42. Rsx base model
  43. Midnight Civic Si
  44. 01 civic with heavy steering
  45. New!
  46. Oil pans interchangeable ??
  47. wind fairing inch?
  48. eu3 k20
  49. K20a2 ticking noise???2002 civic si
  50. Fog Light Wiring Help!!!
  51. The Offical K24a2 swapped ep3 thread...
  52. Has anybody ever dealt with euro type r cams in ep3*?
  53. ep3 headlights
  54. ep3 parts..
  55. New to socal where the ep3s be at????
  56. Need help with ep3 0341 code....
  57. 1st gen rsx tranny into 05 rsx? help no vtec!
  58. OEM RSX Window Visors. Where to buy???
  59. Top speed?
  60. What going on I am new here on honda tech here my ep3.
  61. Rattling noise with Louder Exhaust
  62. DC5 Brembo brake conversion on EP3
  63. 2003 Honda Civic Si Hatch
  64. rsx p0661 code
  65. Ep3 and the Alley
  66. 05 type-s light don't work
  67. P0420, P1166 and P1167 after new cat, new plugs, new O2,
  68. 2002 rsx will not crank..help!!!
  69. Trouble engaging First and Reverse.
  70. RSX Not Starting
  71. rsx timing off
  72. A2 ep swap problems
  73. ep3 dash lights problem:/
  74. ep3 and rsx question
  75. Oil running into my cylinder in my K20/k24
  76. RSX type s PO341
  77. RSX Air Conditioning Problem
  78. Can my 03 Ep3 Type R run lean or rich?
  79. rsx type s Making squeaking sounds when turning
  80. Starter not disengaging in time...
  81. New Moderator in Town
  82. 02 RSX-s EXTREMELY RICH
  83. ep3 vtec doent work!?.. any suggestion on whats wrong??/
  84. only half the dashlight working ep3
  85. oem bose sound system swap
  86. Thinking of selling the EP3 (again) for AP1
  87. HASPORT MOTOR MOUNTS INSTALL (DC5)
  88. EP3 feels dragged down when off throttle
  89. honda meet nov 19th!!!!!!!!!!!!!
  90. RSX Type-S RPM Drop
  91. 04 Civic Si RPMs hang at 4500
  92. Honda part no longer available? WTF?
  93. 02 headlight trouble
  94. Crankshaft Sensor Issue
  95. 143 WHP? 02 rsx-s
  96. Stock 02-04 RSX deck vs 05-06
  97. my car woobles and I am unable to figure out why.
  98. Installing new tranny on k20a2
  99. Vibration Issues 04 RSX-S ???
  100. Intake Air Temp sensor causing stalling?
  101. SkeekDC5 Introduction
  102. Mugen Spoiler Vs. Type R for EP3 (performance standpoint)
  103. PWP RSX Type S
  104. I/H/E question
  105. Jordan Build thread:)
  106. jdm integra type r dc5 2002 bulb headlight
  107. 2003 EP3 wheelspin knock
  108. KMOD RSX Sets New PB & National Record
  109. Are these Rims real?
  110. EP3 Parts in Chicago Illionis
  111. Look out fake Ingalls camber parts being sold!
  112. Please someone help me!
  113. megan coilover help!
  114. So just threw a P0420 code
  115. Broken Axle: 02 Si
  116. Sputtering into vtec
  117. Hey there! Southern NH signing in
  118. 03 RSX Transmitter (Keyless Entry Remote)
  119. need help with my ep3 si
  120. Basic Maintenance Questions on RSX
  121. EP3 Buddy Club Ball Joint fitment issue
  122. 02 Acura RSX HELP!
  123. 02 rsx type s won't go in first or second gear
  124. Question about updating the 2002-2004 RSX to the 2005-2006 setup
  125. eagle sleeved block vs ERl Sleeved block
  126. Rev Hard Turo Kit, boost controller Civic Si
  127. k24 motor. k20 tranny? help!
  128. My RSX is pulling to the left and right!
  129. is there a gasket between header and downpipe?
  130. EP3s have glass transmission? (gear grind woes)
  131. 2002 type s feels slow.. help..
  132. Springs
  133. EP3 Issues... Need some advice.
  134. intalling some parts i need opinions
  135. The Official EP3/DC5 October-December 2011 FS/WTT/WTB Thread!
  136. HEADLIGHT BULB
  137. k20a2 head on k20z3 block
  138. Want to turbo my ep3 need help...
  139. headlights dont work.
  140. Idle problems with my DC5 type R
  141. 05 EP3 violated today at the mall. (body parts stolen)
  142. K20A Type R in RSX won't start.
  143. 01' Arctic Blue Pearl DC5
  144. 04' RSX-S wont start. plz help
  145. P 1259 Code
  146. Whats the Best Tribute EP3 SI Video that you have seen ?
  147. Low beam headlights only on when high beams are on
  148. Bolt Pitch size
  149. New tires on EP3 feel squishy during turns/cornering.
  150. WTB:: 02 EP3 rear bumper light OEM
  151. 2003 ep3 console
  152. k20 head questions
  153. Ep3 Center Console Removal
  154. Question on type-s
  155. Honda Civic Type R Review
  156. Need Help ~ EP3 TYPE R Engine sounds like blowing out
  157. RSX-S Bose stereo problem
  158. Surging Idle and Coolant?
  159. rsx or s2k?
  160. tell me what u think of my ep3!!
  161. what do u think of my ep3??
  162. 03 dc5 fog light help
  163. intermit no start
  164. P0336 in EP3
  165. Mobil 1 0-40w European Formula in a DC5 base
  166. NEED C101 plug pinout
  167. Aftermarket Cat for Ep3?
  168. How to resolve shaking problem on my civic ivtec 2.0 '2004
  169. Weird Cruise Control issue with 2003 Civic Si
  170. Need serious engine help!
  171. is this the ep3 type r headers???
  172. boostin a dc5 r motor
  173. Is this a front bumper strut bar? looks kool
  174. fastest DC5
  175. DC5 Black Dash Cover
  176. Trans Help
  177. wheels for ep3?
  178. 2005 Civic Si, Gross "Polluter"-- High HC at idle
  179. water in the trunk of ep3
  180. 05-06 RSX-S gauge cluster swap into an 02 RSX-S
  181. Is my Power steering pump going bad?
  182. high performance
  183. acura rsx type s
  184. EP3 driver's side window clunk
  185. what color should i paint my 05 RSX Type S
  186. DC5 Recaros into EP3
  187. rsx fuel pump relay
  188. Deciding on kits for my K20
  189. DIY for Springs?
  190. EP3 Specific window shades (not visors)
  191. MUGEN air box or POWER CHAMBER?? EP3
  192. Show off your window tint V.2
  193. got a quick ecu question bout m new k swap....
  194. ep3 and eu1
  195. Coilovers for RSX-S
  196. '05 Type S suspension on a '03 EP3
  197. NEED HELP!!!WHEEL DECISION! PLEASE
  198. Real high prices for used EP3's, right now.
  199. Anyone with the Mugen EP3 K1S0 exhaust here, help please.
  200. NEED HELP ASAP! 04-05 hub questions!!
  201. RSX-S Missed Shift. Need new engine?
  202. steering problem ep3
  203. Resetting ECM Procedure
  204. new timing chain=3k rev limit
  205. ep3 civic type r wing
  206. Looking at a Newer RSX
  207. 02 type s idles low/struggles sometimes
  208. 03 BASE 5speed. general questions
  209. vision air intake duct
  210. Em Racing trunk brace bar rsx!!!!
  211. srs light on!!!
  212. clutch click
  213. EP3 2 seater neater?
  214. EP3 clutch questions
  215. 05 06 rsx muffler
  216. HELP! ALARM NOT WORKING
  217. DC5 2nd to 3rd gear grinding?
  218. 2004 acura rsx type-s engine code p1166?
  219. 02 civic si with zex kit?
  220. MICSPIT EP3 FROM BELGIUM
  221. k20a2 rpms limited to 2k help
  222. exhaust manifold issue
  223. what i need to put my dc2 recaro seat in to my dc5
  224. ep3 starter problems
  225. fans not spinning, cars over heating, spent to much... no good HELP HT!
  226. RSX Radio trouble PLZ HELP
  227. Rsx rebuild and color change!!!
  228. Stretched Timing Chain EP3
  229. Ep3 coilover fit on rsx??
  230. Recaro Seat help
  231. Question for Honda Civic SI Innovative Engine Mount Kit
  232. RSX (DC5) or Integra (DC2)
  233. Rim offset questions.....cant get my head around this!
  234. A/C input 2002 RSX Type S
  235. AC is weak
  236. exhaust
  237. 02 ep3 not running smooth..93k..100,000k tune up? help please
  238. RSX hydraulic clutch problem
  239. D.I.Y Kill Switch Guide for Negative Cable
  240. 5-speed to 6-speed for 2004 Si
  241. Idle issue, common? Help! Video to YouTube inside..!
  242. exhaust leak??
  243. vent pods for ep3
  244. new to the forum
  245. New DC5 Owner! HELP
  246. Header questions
  247. P1298 and Charging System Indicator issues
  248. Strupt header o2 sensor issue...
  249. should i take the plunge?
  250. does something always go wrong with your car?
