- 4 sale Brand new skunk2 turbo 1 camshafts k20a3/k24a1/a3/a4
- EP door lock switch does not work?
- Anybody rockin the function/form type 2 (ver.2) coilovers?!
- o2 sensor question
- Anything To Clean Recaro Seats?
- EP3 Fuel Pump Help
- 02 RSX Type s Rear Window Visor/Spoiler?
- 06 rsx issues
- pnf ecu in base rsx??help
- mini-mi swap HELP
- Tranny/LSD Question?
- Cams
- Anyone ever experienced their JRSC Belt Snapping
- Civic ep3 intake
- Mudguards, how many of you guys have them on your dc5?
- Info on Power Plenums
- K24 transmission
- hard to take out of reverse gear
- Turbo for rsx type s
- Seattle Honda-Tech Meet Pics
- EP3 K20A3 Turbo PLEASE HELP
- rsx base and type s headlight
- 205/45/17 on 2006 RSX-S rims
- help me with my type-s
- ***May FS/WTB Thread***
- squirrelly?
- HELP!!!! ep3 suspension question
- OEM ep3 midpipe with greddy evo2 axleback
- Suspension
- Questions before buying an RSX
- Having problems resetting the maintenance req lights? LOOK NO FURTHER!
- engine or tranny mount?
- tire? 225/50/16's anyone have any rubbing issues?
- does the b blox tps works ok in rsx type s 06
- Please help ENGINE MOUNTS.
- Type-S Tranny vs Type-R Tranny
- Wanted tps sensor for acura rsx type s 06
- K24 question (noob)
- K20A2 - Some CELs and a couple problems
- Stroker kit on an ep3?
- what do some of you use the extra hole in the ep3 dash for?
- ep3 doesnt honk when i lock it...
- ITB...? who makes it.
- need a question answered about rear brakes.
- RBC intake mani and BDL fuel rail?
- Question: Headlight Brackets 03 and 05 RSX
- help with vehicle inspection in Orange County, CA
- how do you change the climate control bulb?
- transmisson noise.
- New civic Si-R
- Sudden bad clutch slipping
- keyless entry problem
- ep3 cruise control problem
- Rsx type s rear wheels and brake help please
- Emission Specs
- what exhaust to buy ep3
- im new to the ep3s
- A-spec wing question?
- EP3 steering wheel.
- Clunk when in park and turning wheel right
- tanabe springs????
- why you should have motor mount inserts for your race header
- DC5 cluster in an EP3
- electrical problem ep3
- RBC manifold and PWJDM Power chamber fitment.
- Desert silver rsx
- ep3 center peice
- eps light (help)
- hks hi-power
- What color to paint my car?
- Emblem ?
- MY powder coated valve cover :)
- 05 si greddy turbo problems
- Anyone selling hondata reflash?!
- Will any K-series alternator and compressor interchange w/ k20a2?
- Clutch pedal adjustment = no grinds
- greddy turbo kit and trade
- EP3 help for a noob
- Headrests
- HELP! looking for a clutch and flywheel for 06 DC5
- 2006 RSX Lowering
- Suggestions.
- k24 bottom end/k20 head
- EP3 intake... No one seems to have tried a K&N...
- offset of type r dc5 wheels with oem brembo brakes?
- headlight replacement question
- DC5 Key
- mugen twin loop or hks power exhaust?
- Sprint hart cpr/track r
- o2 Sensor Problem
- wheel bearing removal help on EP3 Hatch
- Itr or type s
- thrown a code (cylinder 1 misfire)
- coilovers for ep3
- intake manifold help?
- my 02 DC5 is over heating any ideas
- rsx spark plug bolt question
- LCA tool
- Noob? LSD on tranny what oil???
- Anybody have their cluster apart recently?
- noob question valve cover
- K20a3 without AC?
- I got caught with my hand in the cookie jar again
- Question about Camber Kits with Rust on them
- Question On A LSD for a Type-S
- Ep3 Trouble
- thrown a code came up as AIR FUEL METER contROL
- maryland ppl
- worst day of my ep3s life!!!!
- Ridgeline Brakes on EP3
- Stage 5 clutch on stock Rsx good or bad idea?
- i lost the instructions for the fog light.
- rsx rear sway bar on a ep3 ?
- help my bro
- Rsx cluster and climate conrol..no light??help
- 02-03 ep3 H.I.D. visibility
- Vote For Me, Check This Out
- 02 rsx-s tranny swap (help please!!!)
- DC5turbo vs. R35 GTR . MoscoW
- removing AC in a ep3
- base map (help)
- obleezie PwP
- o2 sensor is making me go crazy... HELP!!!!
- 02 Civic Si Hatch Project (Need Help)
- AP2 wheels on rsx type s
- kpro questions
- O2 sensor size?
- Does anyone know of a write up on how to instal coilovers on a 04 rsx????
- fog lights dont turn on :/
- Rsx type s MP2 wheels
- Dc5 brembo brakes plz help
- ep3 and rsx and ht love
- Mugen Aero S
- tanabe sustec pro II, anyone have em?
- k24 question
- k20a2 with k20 internal
- Acura Rsx 05?
- peakbboost turbo kit for ep3?
- New to the EP3
- red honda badges
- they're here!!
- 5th gear pops out
- Beaks Lower Tie Bar
- EP3 Gas Cap giving off C.E.L.
- ITB for the rsx?
- Which brakes would you get?
- EP3 Wheels
- Honda-Tech members in NY and NJ post
- HT Meet in Seattle on April 4th!!
- AEM or K-PRO?? for ep3!
- Type S cat and downpipe on 02 Ep3
- painted my wheels
- !!!!k20z3 into a ep3????!!!!
- B-Pipe questions. Yes, I already googled them.
- Suspension questiones
- 2006 Acura RSX Type-S Rims For:
- quick question about window visor
- Switching out K-pro with stock. Immobilizer options
- Hyundai?!?!?!?
- what would happen if ??(k20a-k20a2)
- F/S type r k20a headers
- for sale type r lip EP3
- wtb: ecu for rsx type s
- the best ep3 engine hp gainers?
- Look for a 06 type S Hondata reflashed ECU.
- Sharper and more respondsive steering....
- ??diff. between z3 block and a3 block??
- callin all ep3 owner v. check this beast out!
- k20a3 block vs k20z3 block?? HELP
- Any ever used a Universal O 2 Sensor?
- EP3 civic type R front knocking
- Lip Suggestions for 05-06 DC5
- ?K20z3 swapped into a ep3?
- Mitsu Evo rims on my DC5
- K20Z3 with ep3 tranny
- Stock K20 HP limit? power limit, boost limit.. still reliable at 300whp?
- Stainless steel bolt kit
- 02-03 vs. 04-05 headlights
- Hoooooorrrrible Knock!!!
- What suspension setup are you running on your DC5
- Ep2 running b18c
- soo long ep3 ;(
- How badly damaged is your RSX..post your pics
- Apexi Super AFC NEP or Hondata reflash.?
- "pass airbag off" ...... Wtf?
- Radio is being freaky
- suspension not going to full droop?
- bye bye type s
- The plus side of wrecking!
- Blew up the 02 Type S... a few questions on options.
- new seats v. pick one please?!
- My Car!
- reflash question
- 02 convert to 05! and bc header and a Q
- '03 RSX-S head unit question..
- 02 Civic si Pros and Cons
- Coilovers
- SE Exhaust on a RSX-S
- Preffered Parts Providers?
- vaiWill there still be RSX-S available in the United States by..
- Wanted: OEM Springs for 04 EP3
- Look what I got :)
- Noob on EP3's
- CEL 7 flashes
- dc5 engine trouble.
- DC5 hits 100k question!!!
- Loose shifter, this right?
- ECU help
- Cleaning EP3 seats
- lowering springs and exhusstt
- Bolt Ons
- wheel hub removal
- usdm ep3 serivce guide
- help megan racing exhaust
- idle problem clutch or not?
- FS: 02-04 stock wheels type s
- Greddy SP2 Exhaust Catback
- bad engine coolant temp sensor?
- how are Megan Racing exhuast?
- buddy club N+ help
- ep3 headlight housing
- injen cai + rsx
- My 03 Si came with Hondata Reflash.. Can i sell it?
- Need help with HID wiring harness.
- what wheels are these/favorite ep3 wheels
- New to the honda world!!!!!
- difference between 02-04 vs 05-06 rsx
- Door not locking...
- Suggestions for coilover/strut setup..???
- 02 EP3 hatch window washer
- Free LSD for a K20 Tranny
- 02 RSX-S Oil issue...
- 1st Time Tranny Fluid DIY
- mid pipe
- I think I'm an addict...
- which spoiler is oem? (confusing)
- Is this the ctr spoiler that everyone talks about? Will it fit an EP3?
- >>spacers for rsx-s help!<<
- 15" wheels on an RSX TypeS????
- New shift Boot
- '03 Si, looking for new wheels
- b18c vs b18c5
- Need your advice on wheels.
- stock wheel
- Header question
- Rough shifting
- bc racing type br coilover's
- High Idle and Fluctuating Idle. IACV and ECU was already replaced by Dealer?
- about to get my car dyno'd
