Radio with no sound
Old Nov 29, 2013 | 12:18 PM
Chavy340's Avatar
Icon2 Radio with no sound
I have a 06 rsx type s. When i replace the stock bose headunit with an aftermarket one, i get no sound and the radio is getting power. Can anyone help me.
Old Nov 30, 2013 | 11:03 AM
caddoo ltd's Avatar
Default Re: Radio with no sound
Check that the unit is receiving the radio signal from the modules located in the roof ,
Old Dec 2, 2013 | 08:47 AM
Sonin Fury's Avatar
I think he is saying make sure that the antenna is connected?
Do you get any from the other inputs? (CD, USB, etc)
I have the wiring and a converter box to integrate into the factory amp.
Also is the radio new or used? My brother ran a pioneer unit for about a year and it just stopped working. Still lit up and you could do everything normal, just no sound, sometimes electronics are fickle.
Old Dec 4, 2013 | 11:55 AM
EFn-DirtySouth's Avatar
what kind of wiring harness adapter did you buy?
Most bose audio systems will not work with just a normal harness...
most likely the internal bose amp will have to be bypassed...
if it is not the correct harness the adaptation will not succeed and you will need to bypass the amp.... that is most likely why there is no sound.
Old Dec 5, 2013 | 06:19 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
It's because you don'thave power going to the amp. Check the brown wire I believe it is. I had the same issue twice
Old Dec 5, 2013 | 06:37 PM
TypeRfit's Avatar
RESIDENT
These two replies are correct.
B16afmaxt
Audio / Security / Video
Mar 29, 2010 03:25 PM
EGRhatch
Nov 6, 2008 01:45 AM
little dx that could
Jul 28, 2008 05:49 PM
TylerC161
Dec 30, 2007 02:40 PM
AaronJ
Mar 24, 2004 06:39 PM
