PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. D.I.Y Inner Rim Cleaning and Painting
  2. D.I.Y Fuel Line cleanup with aftermarket rail
  3. D.I.Y Compression Testing your engine
  4. D.I.Y Rerouting and cleaning up Throttle Cables
  5. D.I.Y Making Your Own Paper Gaskets
  6. D.I.Y Replacing CMC
  7. D.I.Y Making Your own Clutch Line / Tucking it too
  8. D.I.Y Easy way to Bore Manifold or Spacer
  9. D.I.Y Honda Key Conversion
  10. DIY Replacing/Pressing Motor Mount Bushings
  11. tein s tech install, now front passenger side "pops"
  12. k20z1 Compression Test
  13. 06 type s noise when letting clutch out slowly
  14. P1166 (APrimary HO2S (No. 1) Heater System Electrical)
  15. EP3 Fog Light problem
  16. will 15" fit a ep3
  17. Skunk2 IM installation issues
  18. What wheels should i rock...Any Suggestions???
  19. Si side panels
  20. What wheels should i rock???
  21. Electronic throttle body vs cable throttlebody
  22. K series Boost or k24/k20 all motor build
  23. DC5 type r loosing power
  24. Firewall Crack Repair
  25. RSX bose sub help! pic inside
  26. tein spring cutting
  27. Wheel and tire size affecting motor negatively?
  28. ep3 jrsc surging
  29. P0143 Code on EP3.
  30. D.I.Y Easy way to bleed clutch/brakes yourself
  31. Replacing air filter on cold air intake - reset ECU?
  32. HFP suspension?
  33. Which wiring harness is this?
  34. Wheel stud removal question
  35. need help asap.. i got 6 check engine lights
  36. Tire pressure with larger than stock wheels?
  37. Swapping new steering wheel on today!
  38. May be buying an 06 type s
  39. NEED: Electrical Wiring Diagram 2004 Civic SI HB
  40. Need help on a purchase
  41. ep3 front control arms ?
  42. o2 sensor on 03 si
  43. dc5 recaro plastic lever on side
  44. 2003 Honda Civic Si Cruise Control Problem
  45. WTB ep3 rear seats
  46. Question about power variation between years?
  47. o2 sensor location Ep3
  48. Reasonably Priced Brand of Oil for 2004 RSX?
  49. Oil Change - Want to buy K&N HP-1010, Amazon Says doesnt fit RSX?
  50. Intake I made for my swap.. gonna try it out
  51. Need help on finding OEM replacement parts!!!!
  52. Ball Joint(lower)
  53. RSX HELP
  54. Need Help Installing Gauges 2003 Ep3
  55. Prospective RSX Buyer
  56. No v tec
  57. where can i buy new vents?
  58. Too Broke for a full swap
  59. 1.5 lowering srping = tire rub?
  60. RSX sub wire harness the same as EP3?
  61. getting the most out of my stock engine
  62. rsx type r tail light question
  63. a2 head on a a3 block
  64. ep3 detailing?
  65. ep2 gearbox!!
  66. 5Zigen 17x8" Fn01r-C ,ET 25...Poke.
  67. how to; dc2 seats into ep3
  68. 02 RSX radio code q???
  69. B Series in DC5/EP3?
  70. k20 head help
  71. K20A2
  72. K20a Type R speedo and K20a2 type-s speedo the same?
  73. Looking for a good cat for my 03 RSX type S
  74. Check engine light problem
  75. lsv w/ctr's oil light blinking very DIM
  76. project
  77. Ask a guy who paid 900$ for a stock clutch replacement anything.
  78. Wheels For EP3?? And Picture Request...
  79. New to RSX. Gas needle goes up and down periodically
  80. part number for 02-04 rsx rear splash guards
  81. K24a2 in n tuned...
  82. Fuel Return DIY
  83. 2002 civic clutch kit
  84. k20A2 motor wanted
  85. '02 Si stalls at stop
  86. k20 running crappy
  87. new headunit stolen? without faceplate?
  88. double din kits
  89. Quick part question for 02 RSX-S
  90. K20 Questions
  91. Tips for buying a used RSX S
  92. Rear Wheel Bearings w/ Hub
  93. Si HFP kit
  94. Hood Issues
  95. Clutch gone bad, help please.
  96. 2002 RSX-S Runs over dead dog :/ Help
  97. Good sites for rims?
  98. New to RSX, What's the best lowering springs?
  99. stock bose sub speaker wire help.
  100. RSX buddyclub spec II on an ep3?
  101. ep3 with buddy club RSD coilover....
  102. need opinions on rims size?
  103. kpro for 0506
  104. Need Help With Rim Sizing
  105. my ep3 is having stating problems HELP!!!
  106. Decal Placement
  107. hella flush dc5
  108. dc5 type r stock catback.
  109. 03 civic Si hatch back factory service manual?
  110. What offset for 17x9 rims
  111. D2 Suspension problem -2 toe camber
  112. motorcycle sideswept my ep3 need new mirror?
  113. Custom Bracket for Fuel Pressure Regulator
  114. better cold air intake?
  115. 2002 Si, engine cuts out around 4000 RPM
  116. Tein Springs Online
  117. Kpro ?
  118. 03 dc5 lowering springs
  119. Engine rod bearings
  120. car drifts to the right
  121. Battery relocation and venting
  122. si civic muffler
  123. interior color codes
  124. 02 rsx type-s wheels FT !
  125. Type S or s2k ..?
  126. Front tow hook options for lowered EP3s?
  127. Motor Mounts
  128. dc5 mugen ss or koni/spring?
  129. hella-noob
  130. exhust???
  131. RSX springs on EP3 shocks?
  132. brake rotor question
  133. K20 CEL says VTCE Failure?!
  134. ep3 aftermaket oem headlights
  135. rsx color Blue or silver?
  136. Acura RSX Headlight approvals, help required from RSX owners.!
  137. O2 sensor help
  138. Informaiton regarding Slicks & Wheels DC-5
  139. Remote Central Locking Issues Ep4
  140. s2k injectors on ep3
  141. corsport H vinyl...SUCKS. jdm or nothing?
  142. Ep3 suspension upgade
  143. Benen tow hook clearance issue?
  144. Replacing NSX with a RSX, opinions welcome.
  145. How do i know if its a k20a head in a Type S?
  146. SRS Light on dash after installing harnesses
  147. clanking noise if wheel is turned back and forth/ loose wheel- wheel bearing?
  148. K20 in eg question
  149. thinkin bout buyin a rsx need help.
  150. Jackson Super Charger w/KPRo
  151. Battery/fuse box relocation
  152. First ep3..
  153. dc5 recaro seats
  154. RSX Depo JDM Style Headlight???
  155. Question
  156. question about rsx wing/spoiler
  157. '02 civic Si fuel economy
  158. question about acura rsx type-s
  159. rsx-s sub in 2004 ep?
  160. How do i remove passenger side dash airbag? 02 rsx-s
  161. DC5 ABS delete...
  162. 99-2000 civic si wing
  163. Coming Back To The Ep Fam
  164. Em2/EP3 Shocks on RSX
  165. synthetic oil...yes or no? 03 base rsx 5speed
  166. Kpro 4 Sale
  167. help with ep3 window visor
  168. k20z3 swap questions...
  169. no running lights help please
  170. genuine spoon strut?
  171. Red H emblem on EP3 hood?
  172. electronic throttlebody
  173. Hybrid Racing Silicone Hose install/Review
  174. Batteries
  175. EP3 Red Recaro's question??
  176. Thought id update you....
  177. dc5 front seat rocks back and forth!!!
  178. Function & Form type 2 coilover install 02 RSX..lowering the rear-help
  179. RSXs Being Stolen
  180. diy for rear wheel bearings.
  181. k series needs help
  182. O2 Sensor changes depending on the year?
  183. How can I tell what RSX fog lights I have?
  184. interior mods
  185. ep3 Muffler
  186. rsx wont start help asap.
  187. 2002 ep3 k20a3 with 91k miles...safe to supercharge it?
  188. will pistons swap over on K series
  189. Pulling a Michael Jackson (Black to white paint job)
  190. 06 civic or 06 rsx???
  191. convert 02 rsx to a 05 rsx type-s
  192. RSX shakes at idle
  193. Smoke coming from steering column
  194. noooooooob question
  195. What to trade RSX-S for? Eg RDH or 4dr GSR
  196. known issues with rsx?
  197. Questions about 02-04 and 05-06 Rsx-S Catalytic Converters
  198. cooling/heater "problem" ideas/discussion
  199. 02-04 transmission into 05-06 RSX-S?
  200. o2 sensor ???
  201. Noob A/T DC5 Mod Questions
  202. Wheel spacers
  203. cant open doors with ignition key
  204. How much do HFP EP3 rims go for now?
  205. im a noob. quick question for rsx owners
  206. The Official EP3/DC5 FS/WTB/WTT Febuary 2011 Thread!
  207. EP3 thermostat where and how?
  208. Cant DECIDE btw KRAFTWERKS ROTREX C38 vs FULLRACE TURBO?
  209. EP3 Accident :/ help please!
  210. 03 civic si VTEC wont engage and running 1/4 temp
  211. simple oil question
  212. Ep3 Engine build ideas?
  213. stock airbox mod and filter???
  214. High beam not working and blue dash light is on
  215. Upper idler puller siezed? ep3
  216. what color to paint my wheels....
  217. Catback mix and match?
  218. Suspension H E L P !!!
  219. Clutch and flywheel replacement
  220. VTEC Solenoid K20 i-VTEC
  221. help car wont run after kpro install
  222. Side Markers====NEED HELP!!!
  223. Cartman95130
  224. quick question on tire size
  225. ep3 vs rsx rear control arms?
  226. EP3 EVO2 catback work ON DC5?????
  227. dc5 thread?
  228. Poly lips/sideskirts?
  229. My Civic Type-r EP3
  230. Seibon TR-Style Carbon Fiber Side Skirts
  231. Axle back (muffler) options for the OEM/JP/T1R midpipe?
  232. ep3 suspension clunking sound!!
  233. ep3 - HELP PLEASE, car broke... lights for check engine, charging system, eps, more
  234. Ep3 sat for 3 weeks , now car idle fluctuates from 1.5k-2000rpm other issues
  235. Help diagnosing cooling system problem
  236. Going to convert to E85
  237. which clutch should i get? k20a
  238. RSX 02 HELP!!!!!!!
  239. EP3 replaced radiator but still over heating
  240. Is this safe to drive?
  241. My EP3 fan motor (ac) will not turn on...
  242. RSX-S won't start or starts and dies! Help!
  243. Looking at a cheap EP3
  244. Fantastic Civic Si *High Res Warning*
  245. DIY: Modifying Beaks Bar for Progress Brace
  246. Hi all. I wish my first thread wasnt as dire as this bbaaad rattle. opinions please
  247. vtech problems
  248. help, turbo setup for 02 rsx
  249. COBB
  250. clutch slipping...time for a new one but which brand??
