- Is the Greddy Ti C exhaust any good?
- Dead k20a3?
- My crazy Throttle Body Shave! D.I.Y
- 2002 ep3 with k20a2 SWAP - SHIFTER CABLES?
- wat cams for stock block k20a
- RSX new owner (hawaii)
- 2004 civic sport ep2 gearbox
- FS: TURBO RSX-S
- Need help on buying some cams
- thinking about trading for an 05 EP3
- 2002 RSX Electrical Issue
- ep3 check engine light
- rsx heater loss of heat
- Help!!! 2004 RSX Type-S higher fuel consumption and rubbing noise
- New Rsx Owner
- My 2002 Si with Red Emblems Question
- Gas pedel sticking
- EP3 axle wont go back in??
- k20 a3 help!!
- EP3 SI Fuel Issue
- EP3 SI fuel Issue
- K2 front lip for the EP3
- HELP!!!!!!rsx 03 type s
- EP3 exhaust
- rsx cluster in ef hatch problems!
- Should i update the EP3 to 04-05 tails?
- Acura TL AWD 18' wheels
- HELP 02 RSX TYPE S CRANk NO START
- jdm sidemarkers for ep3
- CAI questions base rsx
- 2005 RSX Type-S power loss and higher fuel consumption
- Hatchback Problem!
- rsx start but idle low
- N/A Setup suggestions
- EP3 Civic heater not working
- spoon rearview mirror..?not in blue tint?
- ******** HELP: EP3 POPING ALTERNATOR FUSE*************
- Cams ?? Soping around for a set what are you running ??
- General Suspension education needed :)
- Aftermarket side mirrors for the 02-05 Si?
- EP3 Headlight Lighting
- EP3 HFP Suspension - Retrofitting New Springs
- Vtec Solenoid Valve Service
- ep3 sunroof
- Seat Cover Question (OEM Seat Cover)
- Quick question about 02 sensor on my RSX-S
- need info on k24 and k20a2's..
- Replacing 2004 RSX Boot + Knob, step by step tutorial available?
- buying a ep3
- 03 rsx seatbelt srs issue
- would a TL keyless remote entry work on a RSX?
- Kidd racing header on ebay. Thoughts and legit ?
- '02 to '04 ep3/si headlight conversion. HELP
- rsx mis-fire
- Difference between a2, z1, z3 cams
- Crank No Start: Intermittent
- no vtec k24a1block/k20z1head need advice
- Found a contest for 02-06 RSX's!
- 2002-era Si's- what to look for, especially for transmission
- Tires--touring vs performance
- Eibach Coilover problem *banging sound*
- JP Midpipe (Back from the dead topic i know)
- 02 RSX S mis-fire problem
- Help me play Legos with my Exhaust plans
- k24 head with k20a2 internals.
- guyz I really need ur help RSX 02 check engine light
- average HP on a stock DC5 type r
- Upper Radiator Support Help
- RSX Type S HELP!!!
- EP3 Air bag delete tray
- Tryed searching if a k20z1 crankshaft will fit in a k20a2 block
- EP3 SI questions. I have searched like hell
- Thinking of buying a RSX Type S, Have some questions
- EP3 hitting 1,000,000 miles?
- stock EP3 suspension into 2003 LX civic?
- Exhaust leak
- Helpful Video
- O2 SENSOR
- Seriously fed up.. Knock sensor help.
- Civic SI 03 Diameter muffler
- New EP3 owner here
- EP3 better stop and go traffic performance...
- Just got an 02 EP3 and have some questions
- this is weird???
- vtec not working...still new to honda/acura please help
- UK Owner, Hey.
- 16x8 et44 205/45/16 fronts 225/45/16 rears possible
- where could i find a DC5?
- More Issues with my Rsx...FML
- Picked up a new ride. Problems.
- Door lock actuator gremlins...
- car just dies need help asap
- 2003 HONDA CIVIC SI EP3
- lowest ftg measurments
- HELP with dc5 suspension in an EP3.
- RSX HATCH WONT OPEN HELP!!!
- Radio code
- help PLZ.. need advice asap
- will 15" fit on a rsx?
- 2003 Type S ABS codes 51-01 & 52-02.. Please HELP!!
- are all k series valvetrain/valves interchangeable?
- check out my custom valve cover!
- Lean spot at 2500 rpm in tune
- ...and another EP3 with a door lock problem.
- HELP! WHAT COULD BE CAUSING THIS
- JRSC question???
- Will it pass smog in Ca??
- Rear rotor to small from factory!!
- Seat swap- 05 into 02 RSX
- type s manifold
- S2000 steering wheel - a direct fit?
- Mugen Airbox
- EK steering wheel hub on EP3?
- Someone stole my Honda badges!
- CEL ON and OFF.........?????
- FS: '05 RSX Type - S OEM Exhaust
- RSX HID KIT BULB SIZE?
- ECU
- How often you change your oil?
- odd issue with car.
- Injen intake from ebay!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- rsx tire option stock rim
- Testing waters on my ep3
- Civic SI 03 (EP3) Bumper Lights
- EP3 Loose Airvent Fix Diy
- ep3/rsx bottom mount turbo manifold???
- HELP! Potential Hydro Lock
- difference between a2 and a3 motors.
- Radio code for Acura rsx 2002
- Strange clicking noise from transmission/looking for any type of help
- IAC Motor Testing Clarification
- Thinking of getting an RSX/EP3
- What is this belt here?
- 2004 RSX type S, how to replace Crankshaft Position Sensor?
- quick spring question.
- 02 RSX RIng Gear?
- 2004 Acura RSX misfire Cylinder 1, tried everything...?
- ep3 coil overs
- 2004 RSX type S, ticking sound when idling?
- 2004 RSX Type S-Cylinder 1, 3 misfire/random misfire check engine code??
- JDM Civic EU3 AT to MT
- i have 2 question......
- Widest tires for EP3? Please help.
- ep3 k20a2 jrsc build
- ***Official Gamer Tag/System Chat Thread***
- EP3 K20a2 Swap, Kpro worth it?
- help!! axle/intermediate shaft
- Question about oil..Honda MTF
- K20a3 swap for RSX-S
- OBX THROTTLE BODY
- Did my first RSX Engine overhaul/swap
- Injen Cai /hydrolock
- Belt size for JRSC rsx-s
- 2005 EP3, check engine light came on
- help identify
- A/C Problem!/ New member
- paint matching
- DC5 base clutch
- the drivers 2nd window click dont work..???
- HELP: acura rsx oil pan
- 2 plugs hanging under dash. leave them or no?
- OEM lip for the ep3.
- stock ep3 suspension into dc5?
- make my 1.6i v-tec faster
- where to buy an R??
- P0420.............
- Dc5 JDM ITR headlamp Bulb code
- dc5 trunk problem
- K20z3 header on a K20a3
- Who Makes a 2.25" B-Pipe for the RSX-S ???
- Looking in to buying a 2002 Type S .. im a noOb to K series
- RSX problem?
- Temp Gauge stuck on C
- need help with muddded gaurds....
- 02 Sensor accuracy
- Official September 2010 EP3/DC5 FS/WTT/WTB Thread
- Mod list - Stock 03' RSX-S
- EP3 R owner down Oz way - questions about pinging/detonation.
- Removing instrument cluster on 2005 Si
- Transmission frame mount
- why is this??
- honda-tech vinyl/stickers?
- Which motor mounts to Buy?
- Rsx problem, need help solving
- Autox/ DD Sway Setup
- D2 Suspension
- Finding seats for an 05 Civic si
- Kpro trans swap
- Fuel injector install question rsx
- weird fuel gauge
- Knocking sound coming from valvetrain (VIDEO INSIDE)
- New LSD for RSX
- spoon drop in filter washable???
- Need clarification regarding GruppeM intake.
- -help- electrical problem
- Replacing headlight bulb in 2005 Honda Civic SI?
- EP3 Oxygen Sensor
- EP3 Air Vent issues. Any one else have it? Fix?
- Base Oil Pan vs. Type S Oil pan...
- k20a2 For sale OBO
- Hearing noises from my tranny...
- Odyssey Battery 680 question
- what seats fit in my ep3?
- ported head question
- help with swap in rsx type s
- k20 oil brands
- AC compressor issue. Please help.
- EP3 Conversion from 2003 to 2005
- kpro speedo problem
- Battery Relocation to trunk helppp!! ASAP
- Rsx question ??
- Reinstalled headlights and high beams don't work
- reset ecu pass smog?????
- My new car have K-Pro?
- Rough Clutch Engagement
- wheel bearing?
- Front Break removal
- ep3 Tokico HP fitment
- Set readiness with KPro
- 2002 RSX-S oil loss?
- Spotted a car on the Little Rock craigslist
- TW: Metro Honda Meet in Montclair, California
- Brembo conversion from ITR
- Full Swap Price Questions
- sputtering
- dc5r rails in a canadian rsx, will it work
- NEED HELP PLEASE 2002 honda ep3 si ! sputters , boggs , erratic jolting
- has anyone done the hondata reflash?
- Question On Stage 1 Skunk2 Ver. 3 Cams
- KPRO - Rsx Type S and Civic Si
- CEL WENT ON
- crsx spyder fogs
- Wierd TPS bolts.. How Do I remove them?
- OEM battery questions
- CEL detective work
- CC clutch instal question. HELP! =)
- Rsx CHP inspection.......Need Advice/Help
- types S in an 02 base model rsx
- The Official EP3/DC5 FS/WTB/WTT August 2010 Thread!
- EP3 FRONT LIP SPOILER
- Honda Crv K24a1 head code?
- SPOON ep3 calipers
- S2000 cluster in rsx!!!
- Has there ever been a dyno of a completely stock AUTOMATIC rsx?
- need help with 2002 si in limp mode
- RSX trunk lip spoiler on integra?
- Type S transmission
- Simple hp gains?
- quick question
- tl navi into ep3???
