- New 2002 RSX owner - general questions
- hid dont wanna work on my left headlight
- can i take off a-spec rear lip w/o taking off bumper?
- DC5 fuel filter
- Tachometer Issue, RPM sticking 05 rSX
- rebuild dc5 engine
- k20 immobilizer
- header question??
- Chipped foglight...is it repairable?
- Race header Question for RSX
- anybody have pics of an rsx with a rollbar?
- pros & cons?
- Fuel Rail
- Anyone with Strup Shorty Headers?
- accessory socket problem
- smoking brakes
- type s LSD?
- Rsx Header
- lowering springs.
- Peakboost Powered RSX
- mugen wing dc5!!
- Jack are u in here???????
- RSX-S or RSX
- TPS Civic Si 2005 part #
- jump my foglights
- question on k24 swap
- Convertion
- ep3 k20a 0r a2 head swap
- rsx thats getting no spark
- k20 cams
- HELP! CLUTC AND FLYWHEEL QUESTION!!!!
- Removed passenger seat... SRS light. (I searched)
- 4 door EP3
- switching to the ITR gauge cluster..
- installing a lip kit
- Stroker Kit on an RSX
- 02-05 Ep3 Civic Si and k20a2 swap questions
- BADD GASS why?!?!?!
- New Here.
- easy mods for a ep3 help
- datalogger
- Slammed EP3's???
- Thinking about buying an RSX...
- Lower tie bar funtion. Question!
- 02 rsx type s burning oil?
- hey guys
- WILL 02-04 SPRINGS FIT ON 05-06?
- anyone know where i can find the....
- preferred gas
- Installing HELLA supertones this weekend... You guys want a write up for kicks?
- -License plate light removal-
- Suspension for the EP3. What coilovers are you guys using? Tein, Skunk2, megan, ksport, etc. ??
- Need Oppinions, Suspension ?'s
- attention pat_s
- requesting ep3 2"-2.5" drop
- Spark plugs..help!!!!
- Stock 05 rsx-s rim
- need 02-04 nbp oem rear bumper
- Would you buy this car for this price?
- 2003 civic sir
- Need help with Squeek in the Rain ?
- Loud noise
- 2002 RSX-S Wiring harness
- What Octane Do You Guys Use?
- AEM V2 SRI vs. Injen SRI for EP3
- JUST BOUGHT A 06' RSX TYPE S!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- dc5 to dc2/dc4
- TPS...idle problems
- Another Wiper Delete?....getting mad!
- help why cant i post more then 5 a day
- subframe base rsx
- High RPM engine cut...?
- HID aligment problem for my RSX
- What Kind of lip is this
- New K20/K24 crate motors
- switching superchargers
- alternator
- Visual differance between 02-04 and 05-06 RSX Guage Clusters?
- ******New Autotech Driveline Wavetrac Differentials********
- HELP with tires and brakes(2006 RSX)
- Anyone know where I can get a tonneau cover
- 02-05 Si EP3 with a Spun rod bearing
- Need 02 Sensor
- vtec light
- KPro Not reading Air/Fuel.. No Error code thrown???
- Ran over plastic bag, now axles arent receiving power.
- Rattle @ 3500 RPM, Video Inside!
- Any one know where i can get...
- EP3 HFP Suspension
- is it worth putting a rsx-s trans on my tsx swap for my ep3
- Side air bag light problem
- DC2 R wheels?
- 2002 ep3 firewall
- skunk 2 intake for the 2002 ep3
- running without front sway bar
- Auto down / up function on 02 Type-s broke
- hondata tsx reflash on ep3 ecu with k24swap
- Avid Racing Motor Mount Review - RSX/EP3
- Anyone interested in a set of 16x7 FULL POLISH subzeros?
- will an 02-04 rsx hatch fit 05-06 rsx?
- amp wiring kit question about running the power cable into bay ep3
- Good deal on clutch?
- ep with k24 element motor
- How hard is rear spring installation on Ep3 (2002 si)
- Need some help for wiper delete.
- 04 NHBP Rims...Do i do it?
- PNF ECU on an A2?
- cold air or short ram?????
- Clutch problem.
- installing head unit on ep3 and changing oil
- Exhaust loud and shakey when wet?
- Are 04' RSX suspensions interchangable with 06 RSX?
- Motor Mounts
- Buddy Club Vtec controller
- 02 type s won't start
- rsx type s ecu?
- after market headlights
- New Autotech Driveline WavetracŪ Differentials LSD Cars Wanted!
- Weekend Warrior Autocross
- your thoughts on rear bumper
- turbo safe
- Si suspension
- Pro S coilovers for 02-04 RSX Type S concern
- skunk 2 pro s coilovers ?
- kpro confusion
- Stock Ep bracket on Coils?
- rsx wheel help
- Questions about red EP3 Recaro seats
- ebay turbo for ep3. anyone done it?
- Suspension thud
- after a tune, switched from mrrh to bcrh, now car feels slower.
- flames out the cat running super rich k20a3
- Suspension problem
- check out the deal i got for my dc5
- Location of my ECU?? RSX
- Hondata RSX 227 mph spin
- Another Hondata K-Pro Question
- Need help....
- For Sale/Wanted Thread for September 2008
- O2 sensor throwing check engine light
- Axles
- RIMS HELP!!!!!!
- dc race headers vs shorty with test pipe
- EP3 Fuel Filter
- Transmission Fluids
- K-pro or Relash ??
- Hi! Picked up an RSX-S
- lsd
- Mugen Front lip
- TRansmission fluid drain plug M/T
- What are some good Coilovers?
- check engine o2 sensor
- AC RPM Drop
- Engine Break in Oil?
- air intakes????
- RSX Type S Shift cable replace
- TDC sensor / Cam angle sensor
- DC Race Header, Bolt Up?
- Will bose 6 disc cd player lock if wrong code is entered too much?
- EP3 TIRES AND RIMS
- k20a ecu ep3
- RSX setup
- OK GUYS
- RSX Type S FWD to RWD Conversion...
- GT Motoring RSX - Redline Time Attack
- Anyone run a different oil pan , dipstick question
- A-Spec Brake Pads?
- 02 k20 valve spring retainers?
- rsx head lights
- B&M Shifter
- mugen wing
- why did sparks come out of my exhaust 4th gear at 6500rpm?
- Bought OEM brake pads for my rsx-s. GREASE PACKET??
- Skunk2 Coilover??
- Upgrading to 05-06 Tail lights? worth it?
- Biggest rimsssss
- Side skirts...
- Which color is your favorite on the rsx???????????????????????????
- new member!
- Tail light question...
- Skunk2 and others on Youtube
- New to ht
- Mods that Honda Service won't complain about
- Do they really work?
- New Member
- Do clear reflectors exist??
- Type R DC5 Stock rim size???
- Exhaust pipe Flange springs??
- Daytime Running Lights (DRLs)
- Vibrations
- whats the difference between race headers VS gutting out the cat
- Opinons on turbo choice
- i need cams
- will a 17x7 with a +25 offset fit my ep3?
- Limp mode explanation please?
- k20a fuel system
- POWDER COATED RIMS
- DIY Question: Changing EP3 clutch, do you need to drop the subframe?
- clutch bleeding issues
- Rsx and Integra Seat Rails
- any one use the bcni style side skirts for ep3
- dc5 ?'s
- cluster lights
- DC5 jdm steering wheel
- What spark plugs do you run?
- need help with toda exhaust
- 02 acura rsx automatic to manual
- oil pan wtf!
- help me please. !!!!
- cracked oil pan
- Do I need a wheel alignment? You tell me.
- Need help on a header FAST!
- Good deal on a RSX-S?? 2002 178k miles
- K24 throttle body different than K20?
- 04 RSx type s make weird exhaust noise. HELP!!
- k20a2 head on k20a3
- shifting comfort on ep3?
- itr brembo discs
- is the ep3 ctr and HFP dash just a carbon fiber stick on trim or is it real
- will the jdm ep3 radio/heat control console plug into a usdm ep3
- +0 offset on an ep3?
- Skunk2 Pro-S Coilovers for ep3... good or bad?
- Shopping for rotors
- Most gain for your money
- 05-06 Muffler fits a 02-04 B-Pipe?
- heads for 03 civic si
- Lower grille for RSX
- Pic request "03 Ep3 driver door jam..
- doing the tranny fluid maintance
- can you remove rx engine from the bottom?
- 2002 RSX - CEL on > Air Fuel Meter Code
- Help on buying EP3 on craigslist
- engine wiring harness
- Does anyone know how to connect amp to stock rsx's deck?
- Help What E-brake will fit an ep3??? RSX??
- k20a2 & k20a question
- HELP PLEASE!! Progress Sway Bar Question..
- location of radiator overflow tank.....please help
- Hondata reflash
- Going back to Stock Suspension on 06' RSX
- 05 type s O2 sensor
- New headlight install
- EP '05 and 15'' wheels
- how do i tighten the E brake
- help with factory alarm system in my rsx-s
- 2004 rsx. what is the part number for the rubber piece behind the headlight?
- rota slips, question
- Headlights
- what all can you do to a 2003 civic si?
- DC5 R Camber bolt fitting!!
