Noisy Power Steering DC5 05 Integra
Old Jan 29, 2014 | 08:30 AM
Dunks's Avatar
10 Year Member
Default Noisy Power Steering DC5 05 Integra
Hi Everyone,
I'm experiencing now a loud noise coming from my power steering, worst when in full lock left or right. My Mechanic says that the Upper High Pressure Hose may be the problem and that air has gotten into the system and needs to bleed out the air. BTW the pump is fine.
The genuine hose is like 250US$ amazing!
The hose now has no leaks. So replace with new hose to stop the awe-full winding noise or just bleed out he air??
Anyone have thoughts or had this problem before??
Thanks - Dunks
Old Jan 29, 2014 | 10:45 AM
doood's Avatar
been there done that
Default Re: Noisy Power Steering DC5 05 Integra
Bleed it first. Always try the simple stuff first.
Old Jan 29, 2014 | 03:43 PM
m_shake's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
We've had a TON of v6 accords with noisy p/s pump, especially in cold weather. The problem is the inlet o-ring #11 91345-RDA-A01, so i'd try that first.
Old Jan 31, 2014 | 05:13 AM
Dunks's Avatar
10 Year Member
Thanks I will try bleeding it again
Old Jan 31, 2014 | 05:15 AM
Dunks's Avatar
10 Year Member
Thanks Shake I see if I can source it locally
Old Feb 10, 2014 | 04:49 AM
Dunks's Avatar
10 Year Member
Originally Posted by Dunks
Hi Everyone,
Thanks - Dunks
Well I took the car to a power steering specialist and it turns out it was not the high pressure hose but the pump was bad and some seals in the Rack & Pinion needed changing- cost me a pretty penny but it feels great now.
Thanks again for your feedback
Dunks
Old Feb 26, 2014 | 09:29 AM
rayvo's Avatar
I could be wrong but isn't the power steering system ventilated at the reservoir? Unless you have Electronic P/s, which I don't have much experience with. I would guess it a bad Ps pump. if you come to conclusion thats what it is I have a spare one in perfect working condition.
Honda4Lifex
Jan 27, 2019 01:11 PM
76 camaro car
Mar 15, 2016 03:25 PM
toicy4ya
Mar 19, 2011 01:46 PM
tehjrow
Apr 21, 2010 06:02 AM
