PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. question about ctr rep wing...
  2. Rsx type-s or Honda fit sport ?
  3. acceptable offset and width on lowered rsx
  4. A-spec suspension. Where to go from here.
  5. Ksport camber kit review.
  6. Picked up some goodies for cheap!
  7. The Official EP3/DC5 February 2010 FS/WTT/WTB Thread!
  8. Help Identifying hose to engine? What is it?
  9. The Hazard Switch/Button question? already search
  10. Looking to do something different..Along with an Engine swap....HELP..........
  11. HELP! weak start/no start - IAT/Mass airflow sensor?
  12. rpm problem
  13. Error Code 0340 in kpro CMP Sensor - Signal not found
  14. exhaust size??
  15. JDM DC5 headlights, help!!!!
  16. the thing that hold the fuse box?
  17. Weekend EP3 agenda! (New K Sport camber kit)
  18. rbc manifold
  19. EP3 Only running on 3 cylinders
  20. ctr vs depo
  21. radio error?
  22. BUY MY EP!... THROW ME A PRICE!
  23. how do i remove my headlight in my 06 rsx
  24. Console swap
  25. Worth buying?
  26. EP3 Keyless entry question
  27. Pic Request *Milano Red Rsx*
  28. Red "H" steering wheel sticker
  29. Value of EP3 Turbo?
  30. 02 RSX TypeS Timing Chain Tensioner
  31. will 05-06 springs work with a 03 rsx
  32. missfiring? check engine light...
  33. alternative way to restore your headlights
  34. Just purchased 03 Civic Si
  35. rsx base motor swap
  36. Can anything else make the Secondary 02 throw a code
  37. 05-06 rsx/s headlight socket issue
  38. Advice on Konis for My Rsx
  39. 2003 EP3 Buddy club exhaust issues
  40. Bose Sub Issue
  41. JDM K20A Swap Issues HELP
  42. 03 RSX Choking on idle
  43. Anyone relocate fuse box?
  44. Radio Codes
  45. type-s tranny install.
  46. 2003 EP3 Problems
  47. Need a tie rod...get a generic brand?
  48. Car plans for spring weather?
  49. Honda Emblem in Steering wheel, from which car
  50. Heat Shield fell While Driving and drug
  51. Subs Hook Up?
  52. Zerk fitting
  53. Best eBay Vendor for Fog lights ?
  54. ADVICE 2002 CIVIC SI Catalytic in San Diego
  55. Jumped Timing?
  56. Axle removal?
  57. Question about a dc5 for rsx owners on the board.
  58. How to remove ep3 cluster?
  59. jdm parts
  60. Want to put aftermarket DC4 parts on a DC5..which will fit O.o
  61. little bit of oil in intake manifold??? normal???
  62. Quick question. Where is thermostat housing on K20A
  63. motor question
  64. rsx vs ep3: Same radiator hoses
  65. Need a new trans any help?
  66. Location of PCV on Honda 2002 Civic Si 2.0L
  67. Looking at buying a RSX type S
  68. Help with SRS Hub removal..
  69. constant reving help plz!
  70. Thinking about K-Pro but having doubts...
  71. Seat refurbishing
  72. p1106 code rsx type s seems it has no power
  73. Just bought a 2002 Acura RSX **PICS**
  74. The Official DC5/EP3 Video Thread!!!
  75. Free giveaway from Mishimoto
  76. EP3 rear caliper number
  77. Who have 100k+ miles on their RSX?
  78. DIY: red suede door inserts in EP3
  79. RSX suspension on EP3 what has to be done?
  80. The Official EP3/DC5 January 2010 FS/WTT/WTB thread!
  81. 2002 Si Heater Control Assy
  82. vtec question for k20a3 ep3..
  83. Windshield washer reservoir relocation issues
  84. Car won't start...
  85. DC5 Clunking issue
  86. Thinking of picking up an 03 RSX Type-S, front end damage?
  87. exhaust help?
  88. Alarm wiring diagram for ep3
  89. Replacing tie rods on 06 rsx, help!
  90. Lowrider status to 4x4
  91. Lip kit question
  92. Weird Idle
  93. K20A3 vs K20A2 ???
  94. JRSC
  95. Help, My Window Keeps Falling off it's Track
  96. EP3s lowered more than 1 inch = faster wear and tear on tie rods/steering rack?
  97. ep3 vs. dc5 seat rails
  98. Need Help/opinion on what to upgrade!
  99. 6-Speed EP3
  100. Water on drivers side
  101. Question on transmission
  102. Buddy Club dc5 Racing spec bumper>!!!!
  103. Grinding/Slipping when cold started
  104. Rsx Type S Damage
  105. Cant decide on a new car
  106. door hatch panel
  107. idle problem, need some help please!
  108. help! panel removal?
  109. idel problem hum...
  110. EP3 header question
  111. Question about 2003 civic si rear tail light replacement
  112. 2002 SI hatchback window regulator, Will a 4 door regulator fit a 2 door?
  113. Idler pulley fell off! Help needed!
  114. what does everyone think of this for stickers??
  115. Gf's Rsx won't start..
  116. header compatibility between DC5 and 06 Si.
  117. RSX Steering Wheel Question
  118. dc5 alignment
  119. rsx steel wheels part #
  120. RSX wipers stopped working. Other question inside
  121. Looking for a definitive "how to" on removing a K series from a 04 integra
  122. Help with my EP3 Motor
  123. I have a power problem!
  124. fog light problem rsx
  125. 02 rsx type s rev problem . . HELP!!
  126. rsx issues
  127. Function 7 LCA Spherical Bearings
  128. Hey have questions on RSX
  129. Road Courses
  130. clutch problems
  131. best bang for the buck
  132. EP3 VS RSX TYPE S FRONT LCA
  133. hey need help buying a 2002 si
  134. hooked up battery wrong
  135. lips for the EP civic si. are 02-03 and 04-05 interchangeable?
  136. Buying a 2003 civic si
  137. 60k Service 03 Si...
  138. EP3 Center Console Question
  139. TAIL OF THE DRAGON 16 + 17 2010
  140. kidracing "krusher" header help! fitment
  141. Hondata FlashPro Question
  142. EP3 Spring Advice/Suggestions.
  143. Pro Stock/All motor RSX 9.79@136
  144. password jdm intake ep3
  145. What Octane of Fuel Do You Use?
  146. wheel width?
  147. Start up grind
  148. Civic SIR Hatch exhaust quiet whats good?
  149. 04 EP3 seat belt suck
  150. Question on Type-R Transmission
  151. RSX with Drag DR20 or Work Equip 03
  152. poll and noob question
  153. Official EP3/DC5 December 2009 FS/WTT/WTB?
  154. RSX Dying need some help
  155. Acura RSX LED Dome Light Upgrade
  156. I need to Pass My Emission Please Help
  157. Battery Terminal Too Small??
  158. Ep3 fender liners
  159. tire ware problem
  160. Noise when moving backward
  161. Mid-West Post Your EP3 or DC5
  162. Need HELP asap! need EP3 alternator part number
  163. Wheel Guide/FAQ Thread
  164. 03 DC5 transmission
  165. seperating tie rods from front struts
  166. ***Official: Las Vegas Meet***
  167. offset wheels?
  168. Ep3 h-stock tuning notes
  169. Problem with brake lights on EP3
  170. 02' Honda Civic Si (Shocks)
  171. Price Advice
  172. HFP Kit
  173. 02-04 vs 05-06 type s knuckle HOw to tell?
  174. Transmission Fluid leak
  175. EP3: Most COMFORTABLE daily-driver strut/spring replacement options
  176. so i think
  177. question about rhd conversion on ep3
  178. Alignment + Blown Axle (HELP)
  179. Foot Light
  180. XENON LIGHT IS OUT !!!!! IDK
  181. uknown underchasis x-bar????
  182. rsx chassis number
  183. noob question (ep3)
  184. thinking about boost...
  185. Rsx turbo pricing
  186. k20a3 tuning help
  187. suspension from eg
  188. code p0340
  189. ep3 exhaust????
  190. DC5 iVTEC crossover
  191. Clutch question compatibility?
  192. Rattle from Right Rear Brake
  193. K20a2 head + a3 block...
  194. noobie questions
  195. Spoon Hi Cams
  196. Tranny fluid
  197. biulding a USDM ep3/dc5 type-r
  198. which coilovers are best?
  199. Flywheel for K-Series
  200. wheel and tire question.
  201. Acura Rsx Type S 02
  202. ---- Lowest Coilovers for an EP ----
  203. my poor EP3(DIY body work help)
  204. Injector identification k20a2 vs K20a3
  205. ep3 headlight help
  206. SRS light on - aftermarket seats - questions about dealership...
  207. How to get rid of the green immobilizer light?
  208. 2002 EP3 SI O2 Sensor Wiring help
  209. Clarify for me please
  210. Please Help Ep3 power loss !!!
  211. weird power window problem
  212. cluster wiring
  213. is this possible?
  214. EP3 02 engine swap with TSX 07 help!
  215. EP3 gas mileage
  216. 05 civic si tranny prices?
  217. ep3 owner
  218. any one care for 180mph ep3?
  219. The Official DC5/EP3 November 2009 FS/WTT/WTB
  220. Need Help to Set up a Mugen Front lip for Civic Type r 03
  221. Site Guidelines - Please Read
  222. difference between type s and non type s
  223. DC5 What Type Of K series does it have
  224. Kpro Dealer.
  225. will fd2 type r seats fit ep3 type r??
  226. Question regarding freeplay for second gear
  227. OEM LIP + Mud Flaps?
  228. oil change on a K20
  229. transmission oil
  230. Smart for my auto DC5
  231. z3 tranny(06+ civic SI) bolt up to rsx?
  232. RSX rear caliper bracket
  233. Can't get PND ecu to work
  234. Passengers side door?
  235. dc-5 emblems
  236. type s speakers?
  237. looking for 02 rsx front bumper and both fenders preferebly dsm color
  238. Throw out bearing
  239. Honda Civic EP3 TypeR
  240. 02 type s making weird noise
  241. Raceland coilovers
  242. K20a2
  243. Into the DC5 world
  244. Progress Rear Sway Bar + Tie Bar
  245. question about 1st gen injen EP3 CAI - RD1575
  246. USED KPRO
  247. Acura RSX Glovebox Adjustment?
  248. new front
  249. car is stock as ****
  250. 14" Wheel on 03 EP3??? Will it Fit??
