- Ep3 type r K20A - Injector - help required
- Engine swap problems in rsx type s
- Replaced Engine I. My DC5 02 Acura RSX base model.
- AC not engaging
- RSX-S F20C Transmission Swap (RWD Conversion)
- Engine swap k20a3 02 Acura RSX base
- 06 Type S..Swap In LCA, Knuckle and Ball Joint From Base Possible? Discussion and ?'s
- Rsx type s shifting problems
- Stock 2004 Civic Si - K20A3 with rusty camshafts
- Ep3 type r speedo needle
- 2006 Type S bouncy idle / surging idle / limp mode / stalling / hard start... HELP!!!
- Question About Tuning/Re-Flashing Stock Base RSX and/or RSX Type S
- K20a3 down on power, with troubleshooting.
- Ep3 civic type r- weird wobble/nocking noise when turning left only
- New to forum kseries noob/ep3 questions
- honda civic hatch 1.4i 2003 - low power issues
- Help rsx type s won’t run
- 2003 honda civic ep3 cylinder#1 running rich.
- 2002 ep3 problems no crank
- K20A2/K20Z1 Low Oil Pressure
- Suspension experts, I need some serious help with an issue in the rear
- K20a3 auto to manual harness wiring
- 2006 RSX-S with P2279 and P0507 DTCs
- Thinking about buying this... (2005 RSX Type-S)
- 2003 CIvic Si Coilovers (BUDGET)
- What is this part called ... noticed leak came from here
- Oil leak - any thoughts (head gasket ?)
- Need help with high beam wire harness
- Can anyone tell me where this Power Steering O-Ring is supposed to go?
- Bad MPG
- Replace K20A3 tensioner pulley without removing whole ass'y?
- Ep3 clutch help
- Restyling Lighthouse Installation
- Running lean on simple exhaust mods? Please help!
- 2002 honda civic si high idle
- Help with my 05 rsx non type s heater!
- High mileage ep3
- broke timing all valves replaced now sounds like a UEL header
- Ep3
- 2006 RSX-S P0341 - Seeking Help!
- 2002 Honda Civic SI hatchback new header ?
- Could someone help me out with a full parts list for a K20/K24 swap?
- alternator
- Half the dash lights not working EP3 (where is the how too!?)
- 03 Civic Ep3 Dash Bulbs
- Civic Si 2003 EP3. I need help!
- Need help here
- Fitment
- EP3 help
- ep3 civic si p0137
- Clicking noise from transmission after clutch change
- Looking for a little bit of help putting a parts list together for k20 head
- Final drive swap
- Tranny and ecu
- EP3 Type R Conversion
- K-Series Frankenstein?
- New 2002 Ep3
- SRS light doesn't come on?
- Ep3 Turbo Help
- Light fluttering sound under load
- 02 si missfire..
- DC5 Type R build help
- 2002 Honda Civic Type R starting and running problems.
- What Are These Parts?
- EP3 Type R VTEC engage issue
- Type R VTEC engage issue
- What is this?
- I mess up the transmission 😢
- Speed sensor/ speedometer stops working between 7000 and 7500 rpm
- Pulls to left, then right when warm
- RSX making bad noises coming from something in serpentine belt
- K24/k20 rsx build
- Vibration @ idle and while accelerating?
- Clean up RSX engine bay (advice please)
- 2004 ep3 ebay SRI
- 03 Ep3 bumper lights??
- Production Numbers
- EP3 Drive Conversion?
- front and reat strut dimensions
- Honda Civic EP2 1.6 2005 oil burning ?
- stock k24a2 block with stock k20a2 head on stock type s ecu
- rear upper control arm bushings
- EPS
- 2006 RSX Multiple codes cranks no start
- mysterious idle
- Can anyone help me find this lip??
- Ep3 front lip
- How does one control engine coolant temperatures manually?
- civic 1.7 cdti remove door panel
- 2003 Acura RSX Type-S
- Authentic or Replica Spoon N1 Muffler
- EP3 short ram intake
- 03 EP3 ECU Tuning?
- Incredibly Strange Grinding Sound
- window regulator swap
- Timing Chain Question - K20A3
- EP3 Body Work
- 04 ep3/civic Si hatch with HFP bizzaro questions.
- Reputable company/website for clutch and flywheel?
- Throttle stuck open
- K20A3 Engine - Top Dead Center?
- Funky idle ep3
- is there a piece missing in fender liner/wheel well?
- Half of cluster light is out and no dash lights
- Harmonic Balancer/Fly Wheel Bolt - RSX
- RSX-R Quick Release?
- K pro
- Type R front control arm help !!
- Chilliwack Secondary 12 Second AUTO RSX Build Thread
- HELP!
- 03 EP3 Steering (EPS)
- EP3 vibration on acceleration
- Will i get lift swapping k20a2 cam n rocker assembly in jdm base k20a
- Rsx type a with base motor in it
- 2004 ep3 sir brake upgrade
- 2002 EP3 Civic Ate The Tranny - Now What?
- Rsx base stuck in reverse
- Master clutch cyclinder
- Dc5 with k24 swap jerks when accelerating.
- EP3
- Unusual Loud Whine When In Reverse & Braking
- TEH FUNZ P0341
- EP3 Factory exhaust manifold question
- Ep3 maintanace light reset problem
- 2002 Honda Civic k20 w/ RSX-S Transmission - Loud thud - Video Attached
- Ep3 chassis dc5 subframe?
- EP3 racing coil spring question
- No Crank No Start (2006 Acura RSX Base)
- Can anyone contact the moderators for ephatch.com?
- Left DRL not working - High Beam Is.
- A smaller steering wheel for my EU8
- 03-04 civic engine/engine management options
- Brembo
- 02 RSX (Base) Resonator Delete
- Vetec solenoid failing?
- Civic k20 in limp mode
- Base Map
- 06 rsx type-s block replacement options
- Next to do list?
- Bad wheel bearing feels like the brakes are on?
- EP3 Noise...Video Inside.
- Type R ABS Removal
- 02 Si Squeaking Sound From Suspension, Changes With Speed
- Ep3 Radiator swap causing Temp issues
- 02 civic si hatchback turn signals not working HELP!
- EP3 Steering Wandering
- 2002 civic Si Hatchback fog light switch?
- Honda Civic Type S 2005 Gearbox
- civic 2004
- Dc5 problems
- Can any one please tell me what is this
- Ep3 climate control mode problem
- RSX with K24 Swap - Injector Issue
- Need ignition 12v in Engine Bay Area
- 02 EP3 Control Arm Bolt
- Honda Civic not starting. tik tik sound from self start motor.
- OE Steering wheel swap??
- Serious gas consumption
- Base Rsx midpipe/b-pipe to EP3 stock system
- POWER STEERING/steering wheel play
- Honda Civic si hatchback 2002 shut down while driving and won't start
- EP3 mods?
- Help diagnosing RSX chirp/squeak from steering area (video)
- quick question
- Help ID wire connector
- EP3 wheel offset question.
- '04 Base RSX - Smoke Test Connect Points?
- Picking up a K20A2 trans
- HELP Car Shut off every 2-3sec???
- K series trans makes small continuous grind when in gear? What am I looking at?
- 2005 Acura RSX Problems (Video Enclosed)
- RSX K20A3 Wiring connector
- Integra DC5 Luxury Rim Size Fitment
- Clunking in rear drivers side while turning left.
- Honda Stream RN3 jap import central locking help..
- 2003 si clutch help
- Best oil to use on a turbo ep3 ????
- 07 08 fit turn signals in a 05 type s
- 02 EP3 Transmission Removal
- Heater and A/C both stopped working, air still blows
- 2002 Civic Si Hatchback blower motor
- RSX/DC5/EP3 ABS Delete
- aluminum filler?
- 03 EP3 weird immobilizer problem, no key light at all, no start
- Suggestions on other forums?
- 2002 Civic SI hatchback grinds into 3rd at high RPMs
- RSX fog lights not OEM
- Minor exhaust rumble
- TPS calibration
- Removing doors/bumper protection trims Civic 1.6i 2003
- 2008 acura rsx, can the techs determine if timing chain is wearing out
- HELP, PLEASE!
- adjust valve clearance
- 2002 Civic SI EP3 Power locks and Intermittent wiper issue
- piston rings
- rebuilding K20A2
- RSX Type S Radiator Options
- Honda Ep3 Second key
- What is this box????
- 02' Civic Faulty headlights - ideas?
- EP3 Fueling issue
- today the ignition just stop working 2002 civic si
- ep3
- EP3 Persistent Codes from KS and Primary O2
- 2005 Honda Civic SI EP3 will no start (no turnover)
- cant get vtec to work
- Help with rsx runnning lean
- Starting issue 2003 Civic Hatch SI
- Any idea what this is?
- Is there a Bose system in a base model 2002 acura rsx?
- Intermediate shaft to transmission metal dust cover loose
- 05 RSX TYPE S RBC NEED AIRINTAKE
- Acura RSX chirping from back of engine at idle (VIDEO)
- Civic ep3 2003 starting issues
- DC5 Coilovers
- Tuning Question
- Engine code. P2646
- 03 Civic SI 6 speed swap issue
- Timing Chain
- What the heck is going on with my idle?
- supercharger
- Honda Civic EP2 Main Beams Stuck Half on
- Honda gas cap door won't shut.
- Problems with strut bearings civic 02 hatch
- 30 sec headlight warmup normal?
- First look - RSX Type-S - a decade late
- 2003 RSX base model stock amp or woof?
- Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
- HID
- Rebuilt K24 - First Start - vid & datalog - heating & noise concerns
- accord AC compressor works on k20 ?
- k24a swap
- P0420 definitive troubleshoot
- Basic AC troublshoot
- Need source for Koito wire harness connectors
- K20A3 87 vs 91 octane. Any performance increase?
- HELP! Mystery noise.
- 2004 Civic SI 2.0L Service Manual
- Wiring up engine: what are these connectors?
- 2003 Civic Si Electrical Problems
- Fg2 si steering wheel in ep3?
- 2002 Honda Civic SI HB Fuel relay
- Help me, Drivetrain issues (vibration @2k rpm and sometimes hard to shift)
- Anything to know about the EP3 Type R before buying?
- K24A1 swap into EP3 : more involved than it seems
- 06' Integra dc5 luxury starter motor issues
- how to determine spec of a k-series engine
- Ep3 type r rattles
- 2003 Civic si knocking (video)
- NEED INTERIOR FUSE DIAGRAM EP3
