PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. quick question about power chamber intake ep3
  2. RSX Exhaust
  3. Cleaning struts/shocks?
  4. KPRO question
  5. 03 rsx s action clutch install, problems shifting and whining
  6. Need some help with an Oxygen Sensor
  7. Icebox vs Short Ram or Cold Air?
  8. JDM Honda Integra badges for 03 type-s
  9. fg2 sri on my dc5..
  10. Disconnect battery-ECU Reset
  11. Acura RDX Fuel Injector: 410cc
  12. K20Z3 swap in RSX 2002 need help!
  13. Lowering Springs/ Full body coilovers
  14. Window Tint Help/Opinion Needed!!!
  15. Car wont rev over 3k rpm and is throwing a map code. Need help!
  16. need info on my rims!
  17. EP3 wheels,tires, and suspension
  18. rsx hose???
  19. Considering an EP3, 13 sec 1/4?
  20. What kpro ecu for 06 type-s?
  21. brake pads
  22. ep3 on silverlake
  23. EP3 not unlocking with switch
  24. tires sizing on a 6.5 inch wide rim
  25. help me gurus help my brother
  26. Base RSX 2nd/3rd Gear Lag???
  27. ep3 badgeless grill
  28. HELP...
  29. jdmcarboy muffler vs es tuning
  30. 03 rsx window falls off track
  31. K20A3 valvetrain
  32. ep3 born
  33. DC5 transmission problem
  34. External difference between k20a2-k20a
  35. need help on type of rear camber kit
  36. 2002 true ignition wire?
  37. Axle nut nightmare
  38. No air, hot or cold not blowing at all
  39. Identifying this k-series header
  40. BOMZ Racing intake
  41. k20a2 swap in ep3...need help with ecu
  42. anyone dc5 parts for sale?
  43. OEM Integra Type R Shift Knob
  44. help please
  45. would any body b intrested in trading 09 si rims
  46. ep3 roof rack
  47. RSX Lip Kit
  48. EP3 Overfenders/Flares and Other Questions about Auto-X and Chassis Bracing
  49. rsx type s build. please help!!
  50. Serpentine belt bypass A/C on 03 K20 Civic SI
  51. Anyone heard of "Hytech"
  52. Fog Light incident killed my EP3 speedometer, HELP!
  53. Hondata Air Box Mod?
  54. Type s stock exhaust
  55. k20a2 tranny shift fork
  56. Best CAI for 03 type s?
  57. Car alarm install 02 Si
  58. Hello, new 03 type-s owner here
  59. fs: ep3 ctr computer,immobolizer,switch,key and more...
  60. Transmission ?
  61. Ep3 Throwout bearing issue!
  62. K20 questions about turboing!
  63. What do you think? Enkei J10s
  64. LSD DC5 OEM HONDA
  65. Mugen Front Bumper Questions
  66. Anybody have a 02-04 RSX headlight retrofit DIY w/ pics?
  67. Seat heater question.
  68. need help with suspension set up
  69. bad window seal new to this
  70. Greddy Evo2 Cat back Exhaust how much??
  71. Action Clutch
  72. POST your mud guards/ splash guards
  73. Ram Air Intake
  74. How to Identify a Type-S tranny
  75. help! motor mounts
  76. DC5 integra
  77. Door lock help
  78. Highbeams & blinkers work but not the related cluster indicators
  79. Mugen struts on a SI
  80. brief suspension question
  81. water in trunk!
  82. Question Need help very badly
  83. Oil light stays on after oil pan install.....help
  84. brake pad interchangability question (searched)
  85. shift boot removal
  86. relocated my battery and intake, have a question
  87. DC5 supercharger vs. turbo suggestions!
  88. Budget full coilover, raceland (ep3 application)
  89. instrument pinout diagram
  90. how much should i sell my rsx black leather seats for?
  91. injectors of dc5 on a d15?
  92. Pulley noise?
  93. Weird ac problem, 02 ep3 55k miles
  94. fogging headlight
  95. How to release tension on serpentine belt
  96. type of exhaust
  97. Dc5 Tranny ISSUE
  98. EP3 OEM Wheels
  99. Blinkers and hazards NOT WORKING!
  100. opionions
  101. quick exhaust/CAT question
  102. too stiff shocks?
  103. Need help looking for a thread regarding tail light rewiring
  104. suspected timing chain noise on cold startup only
  105. Does anyone know if a B18c5 will go right with a RSX??? help!
  106. raced a clean rsx-s... :)
  107. 03 ep3 Check engine code p1166 Help?
  108. Need help ASAP im sure this has been covered tsx motor into a type s rsx
  109. B Pipe Question
  110. need new ecu to pass smog wtb
  111. t1r
  112. Front seats for Civic Si
  113. Wiring OEM '02-'03 CTR HID Headlights EP3
  114. 2002 Civic Si AC system trouble shooting
  115. Seats from 2003 RSX to 2002 Civic Si
  116. Front seats in Civic Si '02 and Acura RSX '03
  117. trunk won't open
  118. Totaled my RSX a few days ago RIP dc5, but serious question here
  119. Never really considered the EP3, until randomly now...
  120. ideas on how this was done.
  121. Exedy Stage II Clutch + 9 lb flywheel, lasted 8 months?
  122. Hey!
  123. Base & Type-S ecu
  124. gauge cluster help
  125. Hey GUys need help on eP3 shift linkage!!!
  126. Timing belt?
  127. EP3 Brake Ducts?!?!
  128. RSX-S axleback on EP3
  129. Mishimoto Intake CEL Issue Fixed
  130. Check engine light ON....
  131. What are the measurements of an ep3 muffler?
  132. who knoes how to put a cf trunk???
  133. Spotted silver EP3 in queensbury...WHO ARE YOU!?!?!
  134. rsx-s and ep3 header
  135. 215/55R16 on RSX?
  136. rsx type-s oil pump
  137. aftermarket seat fitiment on rsx
  138. MASS CALLING 2ND GEAR TO AMERICAN HONDA
  139. Future plans
  140. EP3 Key
  141. Cant figure out whats making the noise after radio install!!!!!!!!!!!!!!
  142. Apexi VAFC II settings on K20A2
  143. Civic type R
  144. Exhaust ?
  145. Rsx type s or 2000 si
  146. WHATS A GOOD SPOT TO PUT THE BALLAST FOR MY HID'S?
  147. HELP! Function Form Type-II on a 06.can't fix toe in condition.Tie rods too long
  148. failed smog in my 03 ep3...CEL????
  149. 02-04 rsx with 05-06 rsx front bumper. has it been done?
  150. Ep3 ecu differences
  151. Stock Motor Mount Modification
  152. Ok im back on the boards
  153. what features does this rsx have?
  154. Anyone in PA/MD Area with Kpro Wanna Make $
  155. what k24 would work?
  156. exshaust
  157. 17x7.5 or 17x8 with +48 offset
  158. Swap auto to manual 06 RSX base
  159. compatible front o2 sensors
  160. Immobolizer Help
  161. CEL After ECU Swap
  162. rsx headlights???
  163. Car Wont Start
  164. 02-04 type s springs, help!
  165. kpro help! check engine light flickering.
  166. Megan mid/b pipe
  167. Civic Throttle Cable
  168. skunk 2 or eibachi lowering springs
  169. K pro help
  170. TSX Camshafts
  171. CEL HELP with CPS
  172. CEL & Low Idle Problem!! HELP!
  173. How much Hp will I get?
  174. RSX 02-06
  175. Rsx Base Manuel vs Rsx Base Auto
  176. sputtering in gear w/ the clutch held in.
  177. my new rims =)
  178. i have 2 questions about a rsx
  179. what is your FOB FCC ID#????
  180. ripping apart my block.
  181. thinking of getting a element?
  182. Thinking K20z3 EP
  183. which is better to buy right now?
  184. Exhaust Leak.
  185. will springs/coilovers for a type-s fit a base rsx??
  186. ctr ep3 european k20a2 cams
  187. october 3 speedtrialusa @ buttonwillow
  188. Do any cr-v come with the rsx s engine in them
  189. Got me ITR Recaros and doors
  190. base to type s parts
  191. K20A3 and K20A2 starter motor
  192. Help P 1259 pop up in my si!
  193. Header HELP!? DC5
  194. rota group n
  195. compression per cylinder
  196. What are these parts?
  197. I need pics of buddy club short shifter all around
  198. No heat
  199. Help!! Eibach Sportlines
  200. EP3/DC5 Suspension Tuning Basics/FAQ's (As told by Mustclime)
  201. Air Condition Problems
  202. Do EP3's get stolen much?
  203. quick question
  204. door lock module/mechanism problems
  205. rsx interior swap
  206. RSX weird tail lights
  207. Indoor Fuse Box Panel
  208. 05 DC5, windshield seal
  209. recaro seats help
  210. WA State front license plate petition
  211. new to the dc5, kpro world
  212. Seats back to black?
  213. Racing Harnesses and EP3 seats????
  214. EP3 factory alarm LED question
  215. Looking to purchase an EP3
  216. Finished my Honda conversion today
  217. Help fender liner!
  218. going supercharged
  219. coilovr help!
  220. PRB Kicked my ass
  221. Spreen Honda Meet Sept.12
  222. Springs
  223. Oil type change...
  224. wanna see an SSM with Gold GT3's
  225. Spring Rates
  226. Stock RSX deck
  227. Honda-Tech Meet on 09/12/09 - Seattle
  228. RSX Type-S transmission problems?
  229. Need help with Q's
  230. Will these seats fit ??
  231. wheel studs question
  232. 2010 acura rsx ??
  233. Changing Trassmission
  234. EP3 Electrical question
  235. Cruise Control Block off on EP3 wheel
  236. Kilometers? Wtf
  237. trading my eg for a ep3 si HELP NEED INPUT !
  238. Boost or Swap?
  239. gsr five fives
  240. Fog Light Switch problems
  241. need mods.. anyone?
  242. EP3 Turbo question
  243. Need help In SoCal
  244. Radio code help
  245. EP3 vs ALL
  246. size rims on an ep3!
  247. Stock EP3 Steering Wheel?$?$?$
  248. Slite rumble?
  249. [REQ]Acura RSX 02-04 Service Manual
  250. ///-The Side Build-\\\
