PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. will a jdm ep3 type r gauge cluster, plug into a usdm ep3
  2. any one make aftermerket type r skirts for ep3
  3. Type S swap into a base rsx.....(yes I searched)
  4. USDM EP3/JDM Type R Suspension differences?
  5. K-PRO is it worth it for an ep3
  6. dc5 airbag question
  7. TIMING BELT
  8. rsx seats and ep3 seats for cheap????
  9. do tsx type s wheels fit 05 rxs s
  10. type r center cap part #???
  11. New import DC5 - loosing power through the band erratically - help!
  12. Supercharged Base RSX Possible?
  13. K-PRO
  14. automatic door locks
  15. will i pass smog
  16. jdm ep3 tails r they different
  17. aem pulleys is there a DIY for them???
  18. Check Engine Light Help!!!!!!!
  19. Are race headers illegal?
  20. R.I.P my EP3 before and after pics...=(
  21. BUDDYCLUB P1 SF
  22. how to replace spark plug seals?
  23. Fujita F5 installation!
  24. Goodbye 2006 Acura RSX
  25. does an 06 RSX Type-S come with LSD?
  26. Need help installing an AEM CAI on a 03 RSX type s
  27. Si treats 4k rpm as redline
  28. Volks GT-N
  29. Witch mods for 250bhp on a Ep3 type-r (EDM)
  30. k24 k20a2 oil pan
  31. DC5 Brembo brake model # & rotor question
  32. Will an '06 - '08 Civic Si transmission bolt up and function properly in an '05 RSX Type S?
  33. idle question for type-S
  34. DOEs the k24 and the k20a2 have the same throttlebody mount
  35. What harness is this
  36. Whats normal operating temperature on an EP3?
  37. 2005 ep3 how much should i pay?
  38. parts and pistons
  39. Type-R engine problem!
  40. ok n00b question...
  41. For Sale/Wanted Thread for August 2008
  42. Which Suspension is better for an ep3
  43. help!! engine bolt broken
  44. 05 rsx-s
  45. OEM side-skirt
  46. 2002 Civic Type r (ep3/k20A) with a problem! HELP!
  47. Out of those EP3 owners..
  48. EP3 Shocks 50mm or 55mm
  49. EP3 broken into Planfield NJ
  50. Wire Harness!! HELP!!
  51. rsx fuel pump install help
  52. EP3 Shocks
  53. ep3 rear fog light
  54. 10 point rear lower control arm bolt...WTF?
  55. Ep3 Shocks
  56. can somebody be a pal?
  57. 03 RSX type S oem exhaust diamater?
  58. Rear brake pads (rsx type s)
  59. Type R Link Up In Jamaica
  60. TL Type S/TSX Brake swap
  61. spark plug question
  62. megan coilover question dc5
  63. Wierd K20 problem
  64. ECU reflash ?
  65. need your opinions on these online stores.
  66. How Do You Like Your EP's Handling?
  67. For the "H" grill what do i need?
  68. Wheel offset question......
  69. Wilwood brake kit for RSX/EP3
  70. Honda Civic Ep3 2001-2005 Lights
  71. rsx + skunk2 lowering springs
  72. rsx body parts
  73. Camber kit required for Eibach Prokit???
  74. Are TL Type S wheels a direct bolt on for an 03 RSX Type S????
  75. Mugen DC5 By Toon motorsport Thailand.
  76. Price for 06 RSX Type s
  77. 03 type s srs and abs light
  78. Covina carshow Super Autobacs Pics
  79. p1166 showed up on my dc5
  80. 02 RSX Type-S radio code
  81. H&R lowering springs any good?
  82. DC5 brembo question
  83. ep3 suspention prob.
  84. help building a head
  85. what spark plugs are u using
  86. best intake for rsx type-s
  87. oil leak??
  88. motor mount took a crap on me
  89. ****DC5 Headlights****
  90. 02 Sensor pix needed
  91. need a 02 acura rsx bumper
  92. Honda Civic EP3 2002 - 2005 Bodykit
  93. Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie
  94. Repairing or changing RSX Type S front leather seats...
  95. Smog test
  96. defi gauges
  97. 02 RSX-S Exhaust Leak Question
  98. ::HELP PLEASE:: DC5 won't start!!!!!
  99. k20a3 and type S tranny.?
  100. honda engines superb, transmissions shit!!!!
  101. clutch pedal vibration,feel mushy and creaking sound
  102. wire harness
  103. have 2 questions can u please answer it
  104. picked up some stuff for the RSX *pics*
  105. Missing Jack Parts and Missing Base Speaker in Trunk!
  106. quick question
  107. Need some quick reassurance
  108. Help finding A/C compressor part #
  109. race header vs regular header
  110. VIN number question
  111. 02-03 EP
  112. Rota boost?
  113. Which coilover will give you the lowest drop?
  114. RSX headlight - defect ?
  115. Little help
  116. CAI question
  117. How to reset my ECU ?
  118. What springs to run on 03 type S??
  119. Clutch problems
  120. Where to get cheap emblems for RSX Type S
  121. NOS IN A K20
  122. k20z1 head
  123. replacing brakes of 04 type s
  124. Part number for K20a2 valve cover gasket kit? Thanks!
  125. Falling out of Vtec (k20a2)
  126. k20 miles NEED HELP FAST
  127. please help on a couple options
  128. Why Honda dealerships have different pricing for the same item ?
  129. Difference between 05-06 RSX muffler and the DC5R muffler?
  130. Buddy Club Race Header
  131. EP3 meets, civic meets
  132. SoloII Guide...
  133. JDM DC5 RECARO
  134. 17x7 +49 offset rims
  135. Intake filter
  136. exhaust 04 type s
  137. ep3 injectors
  138. Just finished Valve Adjustment.. PROBLEMS up the a$$(Ep3)
  139. aftermarket cd player hook up
  140. ecu help
  141. suspensions
  142. type-s or s2k?
  143. base 5 spd maint light blinks
  144. ipod + ep3
  145. which coilover without noises
  146. Looking for stock Acura RSX type S 2002
  147. Replacement clutch for the Si
  148. Help with valve adjustment (whiteonrice you there?) or anyone
  149. Member 02 i-vtec read this!!
  150. f20c rwd conversion dc5
  151. k20a3 head......................
  152. Ground Controls
  153. RSX Type S: New Owner finding out some issues... Help!
  154. Civic Type R and SI differences?
  155. NEED NEW COLOR ON MY DC5...HELP
  156. rsx turbo!! help me!
  157. Help please - Navi ???'s
  158. Intake manifold ?
  159. 2003 Civic Si won't stop reving in gear or neutral (1-2k rpm)
  160. Check Engine Light , HELP~~!!
  161. rsx injectors
  162. Wiring for HALO eyes....
  163. Benen tow hook
  164. Replacing RSX headlight
  165. Anyone ever done a K24A SWAP into automatic RSX base?
  166. Help, car dies in neutral...
  167. Was a beautiful day to bring the minivan out on the track
  168. Another fog light question...
  169. pelase hellllll[[[[[[[[[[[[[[[!!!
  170. whats the difference between the ep3?
  171. weird noises in the engine compartment???
  172. Engine rev'ing tooo high at idle!!!???? HELP
  173. 2002 rsx & 2006 rsx info
  174. Camshaft position sensor
  175. k20a3 boost
  176. k20a3 head swap
  177. Type R valvetrain the same as the Type S?
  178. k20a rebuld
  179. WTB an K20a2 please help?????
  180. Which Exhaust system?
  181. arc titan shift knob lost its "titan" finish" any fix?
  182. it worked!!!!! changing the tranny fluid stopeed the grind thanks you everyone
  183. Does the new FD2-R 5.06 final drive fit the 02-04 rsx-s tranny's
  184. RSX Year Comparison?
  185. k20 valve lash adjustment specs??
  186. Loud Valves
  187. Does Anyone Know What The Ho Vtec Means?
  188. Jackson Racing Pulley Problem
  189. Strange noise
  190. if i have a bad third gear syncro, around how much will ity cost to be fixed
  191. 2nd gear to third gear issue more info EP3
  192. Noob needs a header!
  193. HELP!!!! 2nd to third gear shift always grinds 03 ep3
  194. cams
  195. Intake
  196. 5 lug swap on a 02 ep3 questions
  197. Best Motor for 2002 Acura RSX type s
  198. CEL On...
  199. New Rsx-S Bone Stock Upgrade Help plz
  200. Spare key price for 06 RSX?
  201. Immobilizer fried?
  202. Bad noise when i shift!
  203. Performance Parts for Base 06 RSX auto
  204. RSX radiator (FrankinDC5) post in market place
  205. Grill Emblems?
  206. port and polish
  207. Buying new wheels and exhaust. Need help
  208. rear cracking noise
  209. 1st GEAR PROBLEM PLEASEEE HELP
  210. DC5 BuddyClub
  211. jdm land anyone got storys
  212. SPEC Clutch Stage 3+
  213. Idle Problem while braking
  214. which cams gives more power
  215. HID for ep3?
  216. JDM K20A engine for sale on ebay
  217. Type-R clutch and Type-S clutch ?????
  218. To those who have cleaned there IAC
  219. For Sale/Wanted Thread for July 2008
  220. GSR swap
  221. Headlights
  222. 03 Civic Si Starting problems
  223. what does everyone think about this?
  224. Rsx engine swap for h22 whats it take
  225. kpro tuning
  226. Door panel
  227. Engine sound
  228. i need some help with rims
  229. ABS light
  230. honda center caps
  231. How much power?
  232. k20a3 rsx or k20a3 civic si
  233. dc5r rims..
  234. Fog lights
  235. Tightening e-brake
  236. Check your own CEL lights?
  237. 02-04 aspec or type R front lip?
  238. Purge Valve Solenoids - Anyone have a good place to get them?
  239. how do i quiet an exhaust?
  240. Really nooby questions but I have to ask..
  241. Some N00bish Questions...
  242. Where to buy....
  243. test pipe
  244. 2nd Gear miss shifts
  245. COMPTECH spring users, camber kit for the rear????
  246. Another thread about coffin creak.... i know.. sorry
  247. base rsx compression rastio
  248. does anyone get a weird sound from underneath their car
  249. what you think of 03 EP3 w/ 59kmiles?
  250. rsx base and type S engines
