- can a Rsx 06 auto base be swapped into a type s or r ?
- heatshield / header wrap for header on k20a3
- 2002 Acura RSX type s Fender
- How not to turbo your k20
- Weird noise on start up. 05 type s
- K20 (EP SI or RSX) Upper Trans Mount Thread Pitch?
- 06 acura rsx type s
- 5th Gear slips out when accelerating
- Tyre Size 2005 Honda Civic Ep2
- MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
- 2002 rsx type s wont start
- Can I swap a base model k20 into my 2002 RSX type S
- EP1 Vtec build questions plans and help ?
- Used car walkthrough?
- 2002 Honda Stream 2.0 I-vtec
- si hfp
- 15mm or 25mm wheel spacers for DC5 ITR rims on an RSX Type S??
- What is this part (fell out of valve cover)?!
- Honda Civic Si 2004 Inner Tie Rods
- Race car build
- Botched clutch replacement, or something else?
- P2647: Rocker Arm Oil Pressure Switch - Diagnostic and Installation Help
- 03 civic si - starter removal to get to clutch?
- Flywheel for EXEDY KHC10 Clutch Kit
- UK 2003 hatchback driverside door panel removal
- 05-06 type s rsx to 02-04 type s rsx kpro prb conversion/jumper harness
- Hard to shift when not warmed up
- Coolant Flow
- Removing trunk liner 2005 honda civic si
- Brembo big brake and Tein coilover question.
- Rsx type s check engine like code
- What is this part?
- Mystery plug on stock 04 RSX-S engine harness?(pic).
- Question about CAI in EP3
- Help me with the brake lines on my ep3 please
- Wire tucking an ep3 video tutorial!
- Immobilizer removal
- What tires do I put on my car!!!
- Someone help what type of honda is this???
- 04 ep3 engine harness help!?!?
- Buying a civic need help
- BASE RSX want to swap K20a or K24?
- 03 EP3 suspension help desperately needed
- EP3: how much can i get for it?
- 02 Civic Sunroof - is SI interchangeable?
- COOLANT LEAK!
- hi need help asap!
- Max VTC on SVM 212.4 cams with 11.5 k24 bottom
- Vibration With Throttle
- Clutch replaced. Car won't shift into 5th when not running.
- 2002 RSX headlight issue
- 2002 Civic SI P0108 & P1259
- Tips for my first Type R
- Rsx crank but no start
- 500 HP to build my EP3
- Just picked up an 04 RSX Type S for $1500
- How to clean these seats
- DC5 2001 JDM Type R
- Code p1157
- Wanna buy civic SI from someone I know well, what is a fair price?
- 16" Winter Rims for 02 EP3
- Ep3 daily driver
- K20a2 Cam Timing Out...VTC Problem???
- HELP!!Replaced Clutch slave, knocking sound HELP!
- turbo kit install
- 2002 Honda Civic keyfob?
- AC Compressor, Evapansion valve and receiver / dryer
- MASTER CYLINDER AND BOOSTER UPGRADE
- Re-Assemble EP3 Seats
- Honda Civic Ep4 RLY WEIRD Fuel Consumption
- Is this a good type S to buy? 118k miles
- 2003 Honda Civic Multilpe Issues
- 2002 Civic SIR Engine Bay Parts stolen- What am I missing?
- EPS light On, no power assist
- Help K20a2 turbo hesitation acceleration
- Bonusgoat EP3 Thread!
- Questioning my exhaust setup
- Trouble finding JRSC brackets. Help me make them?
- Rsx s 05 help
- Rest in peace EP3 =(
- New RSX owner need help
- EP3 2nd Gear Synchro Grind--Engine Swap Now?
- 2002 Honda Civic SI muffler
- One outer headlight bulb very dim
- Took my new ep3 to a mechanic.
- Srs 15-3 opds sensor replacement
- Ep3 rust?
- Skunk2 coilover sleeves
- Do RSX-S axles fit in ep3
- Car stalling when low on gas
- Wideband X narrowband problem.
- battery relocation simple power wire diagrams guidance needed
- Buying 02' RSX-Type S, Help!
- Moog rear link kit problem Rsx Type S
- RSX-S Axle Replacement issues
- Replace thermostat but rad fan dont work and coolant won't go down
- normal water temp for jdm dc5r?
- K20z1 Wiring
- 2004 Rsx base model fuel pressure??
- F/S OEM DC5 TYPE R HEAD LIGHTS (02)
- F/S Nitrous Express kit
- 04 RSX Invidia Q300 & Stock Cat
- Honda Civic EP1 1.4i D14Z6 - wiring help needed IAT/Idle Air Valve
- Would you purchase this car?
- Learning about LCA's the hard way
- Any RSX owners paint the "A" on the center cap successfully?
- Worth using OEM oil filter on an RSX?
- EP3 TYPE R CLUTCH CHANGE
- ep3 gas cap
- Stab bar and brake kit
- Part #: 2005 Honda Civic Si Hatchback Psngr Side Window Regulator
- Where to buy a replacement bumper cover???
- Can you install ball joint boots without the Acura tool?
- Rsx
- Gas cap door won't close
- Car starts runs then dies
- Ball joint spindle stuck in control arm
- VTEC solenoid going out? (EP3)
- Cranks but wont start (EP3 K20a2)
- CR-V Crank, Spark, Fuel No Start
- 2004 Honda Civic Overheating.
- Low oil pressure on engine rebuild
- Rsx subframe
- Starting built engine without tune
- Header
- Rsx Evap canister problem
- Rsx-s 02, idle problem
- //Buy side skirt//style mugen //DC5//
- EP3 Function 7 Rear Lower Control Arm Bolts
- ep3 broken VTEC Solenoid bolt?
- Anyone know part # for EP3 Rear LCA Bolts?
- Can I use K20A3 motor from RSX auto for an SI?
- hondata 12.5cr file
- Common problems with RSX-S
- o2 sensor heated oxygen sensor
- what swaybar to fit k20/k24
- Honda civic type r
- New to this , frount Engine mount
- EP3 Tune up time. Need some advice.
- oil burn fixed
- 2003 EP3 civic SI Need help.
- fix oil burn from stuck oil piston ring
- Is this Rsx type s worth it?
- Identify this Cat/Header & give estimated value
- 2002 Si - suggestions for maintenance?
- need help, JDM ep3 / USD ep3
- Lights and everything work but car won't start.
- 2004 ep3 making whine noise
- tuning options for 05-06 base rsx
- DC5 Track Picture Thread!
- Help with my ep3 oil pump
- Civic Si 2004 door lock issue - HELP
- 02 civic ep3 EMS vs Hondata
- 210k mile service!!!
- Rsx timing chain kit question
- Coilover choices
- K20a3 engine rebuild
- DC5 brake rotor preference
- 02 EP3 p1166 & p1167 codes
- EP3 Stock Muffler?
- Ep3 all weather floor mat questions....
- Rsx reliability and boost
- 2003 civic si P0172
- Heat/AC shuts itself off (2002 RSX-S)
- HELP!! Black smoke from exhaust running extremely rich
- FIX or SELL?
- NEW TO THE K-SERIES WORLD 2003 EP3 SI
- 2002 RSX Remote Start Install Help
- K20A swapped ep3 question
- RSX won't turn on, lights click
- 02 ep3 no speedo no odomoter
- Help w/ vtec solenoid
- EP3 Belt with no AC
- Got an 06 Type S
- EP CIVIC, CRANKS NO START NO SPARK
- ep3 electrical issue
- EP3 Shifter/boot question
- 2005 EP3 Door Lock Issue
- 05 RSX no heater..
- 2002 Civic Type R EP3 gearbox problem!
- Differences of DC5 and DA9?
- ep3 struggling to accelerate, really bad
- Need help SRS connectors under seats.
- 03 si revs up and down
- Model name to series number anywhere?
- usdm civic ep3 front bumper
- civic ep3 usdm dront bumper
- Why does my Type S Hydroplane easily?
- Automatic 02 rsx build help. Disabled can't push clutch.
- need help, emanage turbo greddy kit for ep3
- boost issue need help!
- Alignment Question
- K20A2 still hunting for idle after many attempts to fix it.
- EP3 Cold Air Intake Box
- Squeak coming from steering wheel
- BROKEN STARTER BOLT! (Upper)
- Petefromthestreets finally going turbo fuck shit up Borg Warner build
- Bigger battery?
- 05 civic si new alternator vehicle won't start
- XTD CLUTCH KIT ON RSX HELP
- 2004 Acura RSX Auto Transmission Issue.
- 2003 civic si k20a3 ep3 bank 1 too rich
- k24a4 in my ep3??
- Turbo ep3
- Good deal on a RSX with blown HG. few questions
- JDM K20A 5 Speed Type S?
- Shaving k20a3 head
- Need help
- New guy, Needs some help with a k20 rsx-s.
- Ordered an ep3 header and got a downpipe
- Did I fuck up my buddy club RSD?
- My 2004 EP3 K20A2 swap
- Ac condensor fan
- 2002 Si civic Hatchback engine swap from a 2.0l to a 1.7l is this possible?
- 2004 K20a2 EP3 Swap Not turning over
- RSX A/T for first car? College
- How To Flush Coolant Honda Civic Type R EP3
- helped needed ep3 wont start
- Power Steering going out
- Frustrated by mysterious clunking noise
- Kmac Caster/Camber plates ride height question
- Starter Motor Location
- EP3 Shifter Cables
- Derp...
- Throttle Body EP3
- Reversing sensor problem
- What engine have I got? & New to bond cars
- Oem camshaft swap
- HFP suspension and OEM bearing and top hat
- Worth performing/rebuild
- Honda Civic Type R EP3 How To Guides
- RSX rear caliper repair kit & bore size
- EM2 to Ep3
- RSX PP and Flywheel Bolts
- A/C relay question(w/picture)
- Known issues with '02 EP3 SiR
- Anyone with an ARC Induction Box?
- K20a2 longblock (no 6speed trans) on a ep3?
- Track Prepped DC5 from Singapore
- My little ep3 build
- RSX tracking stability
- Ep3 fuel pump limit
- 200 cell cat, engine check
- Help me learn?
- Got a PO420, need help from fellow ep3 member in socal area
- Type s
- Fence Post Side Skirt
- p0340 after timing chain change
