(URGENT) Type-s cams and rockers in K20a3!
Old Oct 29, 2013 | 07:16 PM
Spankedrican92's Avatar
Default (URGENT) Type-s cams and rockers in K20a3!
So I reinstalled everything, I adjusted timing chain to proper alignment and torque specs are good... I am now trying to adjust the valves and once I attempt to turn the crank I hear a clunk noise as if the piston is hitting the valves... I loosend the valves all up and re-adjusted the 1 by 1. I need help as soon as possible.
Old Oct 31, 2013 | 09:56 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: (URGENT) Type-s cams and rockers in K20a3!
you didn't change the pistons or valves correct? Just the cams and rocker assembly?
Old Oct 31, 2013 | 10:52 AM
nahonda04's Avatar
Surje.motorsports
what bottom end do you have and what head do you have? what are the modification you have done to the motor?
Old Oct 31, 2013 | 01:02 PM
turbohatchBnuts's Avatar
http://www.k20a.org/forum/showthread.php?t=66643 check this thread out. It may help you.
Old Nov 7, 2013 | 04:25 PM
Sorry for the late response guys....
so I took out the a3 rockers assembly and cams, swaped them out with the TSX rocker assembly and Type S cams and when reinstalling I accidentally over torqued one of the bolts so it got snaped in the head so that being said now I need to take out the head and I was wondering if I swap those type S valves into the TSX head will I be okay to use that without any Valve to piston clearance issues.
And alwo should I lock the pins together if I am not using kpro... I will be purchasing it just dont have it yet, and I know its not recommended but im trying something.
Old Nov 7, 2013 | 04:31 PM
If you look closely you can see the missing bolt, I was thinking about letting it go like that for now because I will be buying another motor during income tax...
does anyone know the torque specs for the head...
on-site
Apr 8, 2012 01:01 PM
S13 slide
Mar 24, 2006 02:25 PM
boosted_dc2
Mar 7, 2004 03:59 AM
CW-ITR-329
Jun 10, 2002 08:23 PM
JDMvtecDRAGSTA
Apr 18, 2002 03:28 AM
